Everything posted by FriedEGs
Do we need to upgrade Braking System with Oversized tires?
FriedEGs replied to gzagun's topic in 96-2004 R50 Pathfinders
Question, do you have the 'Tow/Haul' pads from Power Stop? In other words did you get the Severe Duty brake set? (Most expensive of the 3 combos) What are your thoughts on the braking power and feel? Good initial bite over standard pads? Thanks -
Reviving this topic: Anyone using Airlift with Fluery's 2" kit in the rear? My theory is that the Airlift won't work because the spacer increases the gap between the bottom 'raised' seat and the top portion, (where the bumpstop was originally mounted) Anyone else have experience with this?
Switzerland Trail, just north of Nederland, CO
I remember my first time trying to get into 4L... Like everyone mentioned, def keep the transmission in Neutral when you engage and disengage the 4L. Press down firm and give it a good pull towards you. It's def not as easy as the 'on the fly' motion you get from 2H to 4H. Welcome aboard!
Just to clarify, your cabin heater is normal hot and the engine temp is not overheating? Not sure if your truck is like all other 3.5 litres. On my G35 I had to keep the car on flat land and there was a valve on a hose near the back left of the engine (near the passenger firewall) that I had to open up. Nissan says to fill the coolant through the radiator cap until it overflowed from that valve in the back of the engine. Close the valve and close the radiator cap. (Fill the overflow to between min/max) In the past, with older Nissans I always had to raise the front of the car higher, to try to eliminate air bubbles which didn't work well with my G35. It was best to fill my 3.5L as mentioned above. Maybe give that a try and let the engine warm up to temp so that the thermostat opens. Watch the level in the overflow and fill as needed.
Bad temp sensor can certainly cause misfire issues. The ECU 'thinks' the engine is either cold or hot because of that sensor and is making adjustments. A buddy of mine had that issue on a Ford and replacing that temp sensor fixed the issue.
97 SE, slight hesitation when warm. (Intermittent issue)
FriedEGs replied to FriedEGs's topic in 96-2004 R50 Pathfinders
Thanks guys! I performed a voltage test on the MAP sensor and sure enough, wasn't responding properly. I also noticed that there was no pressure reading through the Torque App / OBDII diagnostic tool. Found a replacement MAP for $4 at a local Pick N Pull and so far, truck has not thrown any codes and has been performing well. Cross my fingers, hopefully the problem is solved! Thanks again for everyone's support. -
Did you ever figure out the cause of this P0105?
Reviving old topic. Any updates on the fix of that P0105 MAP sensor code?
Update: Intermittent misfire still present. Happens after the truck warms up to temperature, especially on warmer days above 50 degrees. Also, stalls at idle frequently. Codes: P0100 MAF Sensor > Tested the MAF circuit which gets 12 volts and the signal is measuring within spec and rises in a linear fashion, while I rev the motor. Also monitoring the MAF signal on my cell phone through the Torque app and the signal is consistent and rises with the increase in throttle. Codes: P0325 Knock sensor. Basically ignoring for now. Codes: P0105 MAP sensor: I tested the voltage at the MAP sensor and reads within spec. However, I have not checked vacuum, yet. Fuel pressure has been constant, so doesn't seem to be a fuel issue. Any idea's on what's going on? -
Jeff, thanks so much for the response. You mentioned the whistling sound which is what I've been hearing for the last 6 months which is the dead give-away to my problem. I ordered the part and replaced it. Take a look at the old part in the top of the pic. Wonder how the heck that blew up the way it did?
CV Joint Axle issues after lift 2 inches
FriedEGs replied to thejazzid's topic in 96-2004 R50 Pathfinders
I found the Warn hubs for $100 brand new from a local seller. (Local seller never installed on his Nissan and he sold his vehicle) I think Amazon has 'em for $175. There is another brand, MM or something like that which are less expensive and seem to be good quality as well. Install was easy, take the wheel off, take off the dust cover, the spring c-clip and the six 10mm nuts off. You'll need to take the old studs out and use the extended studs that come with the new hubs. Just use the old double locked nuts trick to get those studs out. There is a sticky write up on how to install on the board. Ball joints I used Moog on the lowers. Good stuff, so far. For lift and suspension, I just used some Gabriel's that were on sale with stock springs. I used the spacers above the strut/top hats which were $200 bux for front and rear and raised the vehicle 2"s which is great for CO trails. (31" tire as well) Look up "Fluery" in the search and you should find a member, based in Canada that supplies these parts. His website is http://4x4design.com/ Highly recommend! -
R50 Tire Carrier Mod: Let's settle this!
FriedEGs replied to hawairish's topic in 96-2004 R50 Pathfinders
If you're anywhere near the Denver area there is a 96 SE with a carrier, in good condition. (Mostly surface rust) Located at the Littleton U-Pull. (South Denver) -
Your setup is basically what I now have on my 97 SE. (2.5 front spacer with 1.5 rear) I added new shocks and also have 31" tires. One thing I did to help reduce the wear on my front axles is to install some front locking hubs. (Warn) Since they basically release the front axles from the hub you reduce the wear on the CV joints since they no longer spin with the wheel. Obviously you won't be able to shift into 4WD on the fly, unless you keep them locked. So, right before I hit an offroad trail, I'll step out and re-activate the hubs so that I can utilize the 4WD shifter on-the-fly. (Same with snowy days, I'll just keep the hubs locked until all the snow melts.) As a huge benefit, you'll save about 3 MPG which will pay for the hubs in less than a year with normal mileage. -
Oil Leak: 3.3L Above Pan, below cam seals/valve cover...?
Thanks so much, I totally did not realize that the oil sender was right behind the filter. Turns out this thing was gushing oil right through to the plastic connector. Replaced and no more leaks! Thanks again!! -
This was exactly the problem I had for the last 6 months until that distributor finally crapped out. I kept chasing the issue down to the IACV, cleaning it up. Update: Just repaired another oil leak by replacing a blown out oil sending unit. This thing was gushing oil through the plastic connector. Truck runs much better now, but had one misfire while driving it tonight. -
Here is the progression of my latest issues: First, I had a distributor conk out on me, replaced it with an OEM Nissan reman unit and the truck has been running great ever since. However, a month later I started experiencing some starting issues with both cold starts and slightly warm engine. (After sitting for 1-2 hours max) To get it to fire up, I had to crank it multiple times in 15-20 second intervals. Lately, the starting issue has since gone away but now I have experienced an intermittent hesitation, mostly after the engine warms up. Basically feels like a misfire and typically happens under hard loads, such as accelerating up-hill on the freeway. The other day I was able to 'create' the misfire by jolting the steering wheel hard in order to 'shake' the truck while at medium speeds. (around 30mph) Additionally, the truck will sometimes just 'die' when slowing down to a stop or many times while at idle, both in gear or in 'park'. But, it will restart immediately with a turn of the key. This intermittent problem only occurs briefly and usually only happens about 5-10% of the time, while engine is running and/or driving. Again, distributor seems to be working properly. New plugs, new wires, newer fuel pump, all hoses to intake manifold appear to be fine. Also I tested the MAP and all the BARO switches below the intake, right above the AC compressor with positive results. (I checked voltage and continuity) After reading through JeffsR50 six page 'won't start when warm' thread, I'm starting to consider that this might be related to the cut off valve which is located under the truck near the rear axle. (In-line between the EVAP canister and the fuel tank.) However, before I purchase one of those for $60 I thought I'd gather some input based on the unique symptoms I've described. Thanks in advance!
Soo.... been reading through this thread for the last hour. (Stopped to hit the restroom and grab some snacks) The information has been very insightful and hopefully leading me to the right track with my own issue. Question to JeffsR50: Is the picture below the same as the cut valve that you replaced? I haven't been under the vehicle yet, but what simple tests did you perform in order to determine that the valve was stuck open?
Alright, been chasing a few oil leaks on my 97 SE. (3.3) Replaced both valve cover gaskets, which helped. Noticed oil leak from right above the alternator. Tore down to the Cam seals and sure enough, the passenger seal had a pin-sized hole and oil everywhere. Replaced both cam seals, replaced the front main seal, behind the crank pulley. Unfortunately, still have a significant leak from somewhere else on the front side of the motor. It is def coming from higher than the oil pan and the oil pan gasket appears to be fine. What am I missing? Is there another source for oil to leak? Is there a connecting point between the oil filter housing and the block that I am missing? The engine is so dirty from all the previous oil leaks that I can't tell where the fresh leak is coming from. Thanks!
I actually don't have any pics saved.... Once I get a nice bath on my truck I'll get some pics together.
Pat, anyway you could show us which exact ELM you purchased? There are so many out there and the one I have works on my other vehicle, but not the Path. I know there are different versions.
Have you pulled a spark plug to see if fuel is getting into the cylinders? So far, seems like the fuel is getting to the rail, but the injectors are not performing. I believe there is a dedicated fuse for the injectors, so check that first. If blown and replacing still snaps the fuse, then you'll need to perform some tests on the injectors. (Power, ground, signal, etc.)
I sanded mine down and spray painted it with 'Roll bar' paint from local parts store. I shot up the upper spoiler/diffuser as well. Both turned out great!
No problem, let us know how it turns out.
Suspension Sag, one side only. 1997 SE
No issues to all of those points above, except the last one. On the LCA's, shouldn't that rear point pivot within the rubber bushing as the suspension flexes? Does that u-shaped bracket that holds this LCA need to be tightened when the vehicle is sitting on ground? (Same with front inside bushing)
