thorpe991
Everything posted by thorpe991
  1. so im thinking to get the light out put I want Im going to have to use led and halogen lights so im thinking after looking at the price of led bars to go with one that would be mounted on the bumper -and put two halogen lights on the roof .
  2. Ok so how do I get it out once I to move the bolt? Sent from my iPod touch using Tapatalk
  3. I'm going to order some next week but if I was to hook up the spots I have from my truck on to my bumper would I be able to splice into the fog light wiring or do I have to put a new switch? Im going to leave the LEDs if I was to do this so I would have 4 lights running of my fog switch Sent from my iPod touch using Tapatalk
  4. I would be running them only when I'm on the back roads I had some 4x3" spot lights on my old truck and they did the job perfectly to light up the road but they were on the bumper I still have those lights but there a box style and in think they would look funny on my pathfinder and the reason I put that about the fogs is because I thought they would be bright . Which when you stand in front of my pathy they are bright white but they don't put light out on the ground I've tried putting that at all different angles Sent from my iPod touch using Tapatalk
  5. So my abs sensor went on the left side so I went to the jy to get a used one but can't get it off I took the bolt out but can't get it(abs sensor) to come out of the hub what am I doing wrong? Sent from my iPod touch using Tapatalk
  6. Haha so how would this sound like a carnival ?? Sent from my iPod touch using Tapatalk
  7. Ok so I want to put a light bar on my vehical in front of the sunroof or at the front of the sun roof I like the look of the led bars but I have led fog lights and I'm not happy with the light out put so my ?s are 1. What put out better light ( area coverage ) 2. Is there away to hook one to the stock roof rail system 3. What brand should I look at for both led and a kc style light system 4. What do you run and or have tried 5. How did you run the wires to the switch inside and what mods did you do for the extra power needed ( I have a sound system that's pulling more power than the normal radio would Sent from my iPod touch using Tapatalk
  8. I put my wheel spacers and green diamonds on chevy rims on in the snow Sent from my iPod touch using Tapatalk
  9. It depends on if you have a wd or r50 because there are no headers at the moment for the r50s Sent from my iPod touch using Tapatalk
  10. That a good idea Next time ots not snowing ill have to try the chisel idea Sent from my iPod touch using Tapatalk
  11. Right now I have 2" pipe running from the cats to a thrush turbo and then 2" tail pipe no resonator
  12. ya i know but the reason no battery operated tools is that they dont remove the fuel lines or somthing like that
  13. mine works fine and if i dont fill up as soon as the light comes on i have to put in 18 gal but if i do when it first comes on its usually 14- 16 gal
  14. i pulled my fuse because when my sensor or whatever on my abs gets wet it makes the whole system tweek out i have the abs light on but not my break light and its going on 2 weeks now
  15. No there not restricted but I like the fan/ mist style my dads truck has over the stream and I have two streams that hit equally spaced in the middle /top and two that hit on the outside /bottom Sent from my iPod touch using Tapatalk
  16. Ya well I went over to get them and one side came off beautifully and the other side had 3 stripped Allen bolts that hole the dial thing in so it was a no go unless you guys no off a way to get them out , local jy doesn't allow power tools or battery operated tools I tried to go the next day with a drill and easy out and they stopped me at the door an said I couldn't take the drill in but they could go in and take it out ( the allan bolt) for me at $20 every 15 mins it takes them Sent from my iPod touch using Tapatalk
  17. This use to happen to me with my gmc what the problem was is that the ground wire on my sending unit was broke about 1/4 of the way across the wire and it would run fine for a while but if it would randomly stop working and then it would just magically start working again so I would check that and if you changed the sending unit recently check and make sure it is plugged in all the way that happens to me to. When I replaced the broken one Sent from my iPod touch using Tapatalk
  18. That's what I thought o well guess ill have to start searching do you no if the 99.5 to 04 pathfinders have stream or mist? Sent from my iPod touch using Tapatalk
  19. so mine front and rear shoot solid streams is this normal? and if it is how can i get it to spray a fan of mist style? if it is not normal how can i fix this? my issue is that the few times this winter that i had ice on my windshield the sprayers only put 4 holes in the ice instead of a full window melt ( i have deicer spray) is there a universal replacement to make them a fan spray or am i stuck with streams? the back doesnt bother me as much but the front does
  20. do you know which buttons mine dosent have which buttons to push mine is a 97
  21. Man i wish they were here I think I might trade my camaro for one if there were in the states haha Sent from my iPod touch using Tapatalk
  22. what year is your skyline iv been in love with the skyline gtr r34 since i watched fast and furius 2 and i wish they were in the states i know of one that iv seen with my own eyes it was at a car show here in ny called art de Ferrari it was the only non Ferrari or lambo and it had the biggest crowd around it and it was a gtr34 i couldent belive my eyes i have a list of cars in my head that i want to see in person before i die ad that was one haha another is the gt-r (not the skyline) and i saw one this summer at the local target
  23. ok guys so tomarro im going to get those hubs and i was wondering about once i get them installed how do i get into 4wd (all of my vehicals have been on the go so im a lil lost) i know i put the 4wd shifter in to 4 hi but after that im lost
  24. Cool I have both of those in my garage now if I can find them Sent from my iPod touch using Tapatalk
  25. Ok looks like ill be heading back there tomarro to get them so this is prolly a dumb ? But how do I remove snap rings or better yet what tools will I need to remove the hubs I know a Allen rench but what else Sent from my iPod touch using Tapatalk
