49
Everything posted by deltaR50
VG34e Powered R50 Adventure/Build Thread
deltaR50 replied to deltaR50's topic in 96-2004 R50 Pathfinders
may 2015 USS Hornet -
first drive after fully installed the sfd and bigger tires/wider wheels. some flexing yea -
may 2015 snatch me some 15x10 steel wheels off craigslist. also some meats 33x12.50x15 to go with the wheels so i can get rid of the ugly gaps. looks like rig is skipping leg day from the gym lol -
may 2015 after install sfd install front rear before after 2 inches coil spacer lift vs sfd 6 inches lift. both are my rigs. 245/75/16 vs 235/65/15 -
may 2015 rear removal of shocks and rear coils drill out the hole to fit the bolt for the 1 inch wj coil spring adapter. new vs old coil spring and rear shocks 5100 bilstein coil spring, rear shocks, extended sway bar links, kr fab pan hard drop bucket and 1 inch wj coil spring adapter installed -
may 2015 front lift installation engine support block is in. subframe dropped ready strut spacer and nx 1 inch spacer installed -
may 2015 front struts removed 14mm x 3 on the tower. then 2x 21mm nuts for the spindle side placed jack stands on the transmission to hold the engine not falling off when the subframe is being unbolted. dropped the diff.bolted with 8x 17mm on the diff mount while the cv is bolted on the diff with 6x 12mm each side. its must easier to move the subframe without the differential bolted in. also gives you room to remove the engine mount nuts 14mm nuts steering link removed. -
SFD install may 2015 before install rears front -
i know thanks! -
yea. its in carnegie. years back. ive been also to modesto area. stay tuned. ive got @!*%load of pictures to post. -
may 2015 few months ago i got lucky that i found someone local that sell his sfd kr fab kit. i think its one of the last production run at the time. i think i paid $600 for everything at the time. 5100 bilstein shock wj coil spring 1 inche rear wj coil spring adapter steering extension strut spacers kr fab pan hard drop bucket sway bar links -
first off road trip after the full maintenance carnegie svra in livermore,california dec 6, 2014 -
other pics -
first drive after the full maintenance done. USS hornet august 2014 -
******june-july 2014****** since i planned to build this one i decided to do a major tune up. so when i start building it for other uprgades i dont have to worry about its reliability. parts replaced were timing belt waterpump oe thermostat camshaft seals oil pump seals sparkplugs sparkplug wires valve cover gasket valve cover screw and gromets intake manifold gasket intake manifold allen bolts (oe were rusted and falling apartt) heater hoses knock sensor painted rust protection for the heater pipes under the intake manifold cleaned egr new egr gasket new power steering. alternator and ac belts new radiator hoses new starter since im putting a new knock sensor. i pulled the intake plenum and manifold. heater hoses and knock sensor are pretty accesible while the intake mani is out. installed new gaskets and valve cover ones did the timing belt and waterpump gave me access to this might as well change it while im at it more work new valve cover bolts old place. where i learned how to wrench -
just checking local craigslist. no intentions of buying another pathfinder since i already have one. found this as a mechanic special. it doenst start. listed at $600. checked it out the bought it. towed it home. just turns out bad starter. 178k may 8 2014 -
hello guys. i just wanted to say Hi again. ive been a member here for a while now. go here and there once in a while. ive been building this truck for 4 yrs now and i just never had the time to create a separate build for this truck. will post pics and vid. stay tune! truck specs. 96 Se3.4 vg34e euro camsKr fab Sfd+aluminum 1 inch spacer front 5” rear 6” rear wj coilsKyb front struts5100 bilstein shocks rearCustom front bumper Smittybilt 9500 winchJeep fogsWelded frontNavara snorkel d21Spectre 4 inches inline intake33x12.50x15 cooper discoverer sttWarn manual hubs6k led headlamp bulbsAdditional aux fuse box Arb air on board compressor15x10 steeliesGas canCb radio2x 7 inches Rear led lights4x 7 inches front spotlights2x 7 inches front bumper lightsRock slidersGround kitTrasharoo lolfull catback exhaust new piped 2.5 with Flowmaster 40 Tow hitchNissan oem diff plateRola vortex roof rack with custom mounts for flush and low profile
seen it.
im not sure if i have a build thread for this black one. heres my old thread
yep! salvaged
Hawairish and TowndawgR50 are teaming up!
deltaR50 replied to hawairish's topic in 96-2004 R50 Pathfinders
here's mine- 155 replies
- 3
- sfd
- trailing arms
(and 3 more)
Tagged with:
