deltaR50
Everything posted by deltaR50
  1. Check the injector clips. Those are the ones that will give u first electrical problem
  2. Sry to hear your loss. how are the lift springs? Still good? How much for the rock sliders shipped to 94501?
  3. where did you get those front and rear bumper from? interested with the sfd kit as well.
  4. Can anyone verify the wheels? Looks good with all oem look on everything
  5. i recently did both power valves and swirls valves while at it,replaced the old screws with new ones. got them 24 cents per screw from ace hardware. size and thread pattern is m3x.50 10mm length, then used the high strength red loctite so i would have a peace of mind those screws wont come out. i would recommend to change the intake manifold gasket, pcv,valve cover, spark plug seal, emission valve cover hose that connects both valve cover since they are plastic and get brittle, while u work down there because everything has easy access while the intake manifold is out. do it once and do it right the first time. as the torque for the intake manifold. i did all 12mm bolts and nuts at 20lbs.
  6. we need to meet up buddy. im local to you! nice truck!
  7. i just did both power valve screws and swirl valves today. will post a full write up later on. thanks for this info
  8. when i bought my 01 LE 4x4. it had a visible leak from the rear diff. all i did was check the fluid then re tighten the plug. cleaned it then never had leak ever since.
