deltaR50
Everything posted by deltaR50
  1. Dave upload them on youtube then copy and paste the link. Itll automatically populate.
  2. may 2016 sf bay area NPORA r50 meet Union City, ca npora members xplor4 and enjoi408.i forgot mikey's npora user name. (gray r50 pathfinder)
  3. march 2016 update snorkel installation i had to be creative at least with this one. i almost went for the xj cherokee snorkel but i went for d22 navara snorkel as it has easier to custom pipe it to the intake. i eliminate the stock airbox and replaced it with spectre 5 inches inline intake i had to make some adjustments to make the spectre to fit between the maf and snorkel. 1x silicone coupler reducer plastic intake tube 2.5 outside diameter to 3 inches outside diameter to maf 1x silicone coupler reducer from maf with maf adapter with 3 inches outside diameter to 4 inches outside diameter to inline intake 1x silicone coupler reducer from inline intake 4 inches outside diameter to snorkel with 3 inches outside diameter to mate. marking the spot where to punch a hole. eye balled it................... tried to use the template for d22 just for the holes to bolt in. removed fender. as the spot where im trying to cut. i had cut it squarish only for me to make the intake tube fit. spray painted at least to prevent rust snorkel installed. truck still shiny lol
  4. Feb 2016 Frank Raines OHV patterson, california
  5. Feb 2016 Frank Raines OHV patterson, california mud bath
  6. Feb 2016 Frank Raines OHV patterson, california
  7. Feb 2016 Frank Raines OHV patterson, california group pic with the boys
  8. feb 2016 Frank Raines OHV patterson, california
  9. same day after wheeling on carnegie we also dropped by at frank raines OHV
  10. feb 2016 carnegie SVRA in tracy, california. weekend with my small circle parts added roof spot lights 7 inches HID 6k front brush guard lights 7 inches HID 6k 48inches hi lift jack custom mounts on roof basket
  11. Also towndog is the man. He also did welded my sfd back then. Awesome dude.
  12. Yea i got my eyes on that too. Torn between where i just make a simple custom mount on the spare tire carrier. Ive had my hi lift jack mounted on my roof basket for at least 3 yrs now and it never got loose even once. Lucky.
  13. im also on the same route. gonna move my hi lift on to my spare tire carrier when i get the chance. just been busy and working spot is starting to be an issue.
  14. you cant bent a valve just by having the cam slips while you are repositioning the belt. unless you put it wrong then start the engine then there you go. other than that you should be ok. ive done swapping timing belt on my mine and few times and also have the cam gears slip when i put the timing belt back and engine is fine. you should be good
  15. sorry to hear that. i was looking forward to wheel with you around modesto area in LA grange OHV in the future bro
  16. Gates is the current oem parts nissan use right now. When i did build my vg34e engine i want everything brand new. Order parts on local nissan dealership and found gates are the parts used by nissan to supply
  17. oct 2015 rola roof basket extension is added. remove the old factory roof rack broke on me so it has to go. also bought conduit clamps to mount the roof basket for more strength on the mount. parts you need for low mount roof basketonly works if your roof basket has side pipes like rola vortexparts needed- m6 fender washer - m6 stainless steel split washer - oem roof bar mounts - 1/4 inch m6x1.0 bolt
  18. july 2015 hollister hills svra ascending to the top
  19. july 2015 hollister hills svra more flexing! flexing with my crew
  20. july 2015 hollister hills svra testing the goodies gas can added on the factory spare tire carrier inspired by theexbrit also a member here. crazy flex!
  21. june 2015 purchased used warn manual hubs here from another member. just dont remember who. it was steal. $100 for 2 pair of manual hubs. 1 pair is this warn and the other one was an oem manual locking hubs from nissan factory. warn manual hub installation. removed auto hubs, 6x nuts and studs, c clip installed warn hub
