49
Everything posted by deltaR50
Installed my rear lift. Tomm Is the front
does anyone have a snapshot as title says? im curious how the cv axle angled looks
95 XE Check Engine Light still on after new parts
deltaR50 replied to crs34321's topic in General Forums
I would try to check the connector clips. Since its 95 i would assume The connectors would have corrosion in them. Or the clips are barely making contacts. -
Love duratracs.
Check the injector clips. Those are the ones that will give u first electrical problem
anyone else makes these 2.5 sfd kit?
where did you get those front and rear bumper from? interested with the sfd kit as well.
Well I installed Kryptons SFD. My opinions
deltaR50 replied to dustinp's topic in 96-2004 R50 Pathfinders
Can anyone verify the wheels? Looks good with all oem look on everything -
i recently did both power valves and swirls valves while at it,replaced the old screws with new ones. got them 24 cents per screw from ace hardware. size and thread pattern is m3x.50 10mm length, then used the high strength red loctite so i would have a peace of mind those screws wont come out. i would recommend to change the intake manifold gasket, pcv,valve cover, spark plug seal, emission valve cover hose that connects both valve cover since they are plastic and get brittle, while u work down there because everything has easy access while the intake manifold is out. do it once and do it right the first time. as the torque for the intake manifold. i did all 12mm bolts and nuts at 20lbs.
we need to meet up buddy. im local to you! nice truck!
Power Valve Screws Falling Out On 3.5's, 01-04
deltaR50 replied to Trainman's topic in R50 FAQ's & Pinned Topics
i just did both power valve screws and swirl valves today. will post a full write up later on. thanks for this info -
when i bought my 01 LE 4x4. it had a visible leak from the rear diff. all i did was check the fluid then re tighten the plug. cleaned it then never had leak ever since.
Beater/DD r50 Pathfinder - Gotta Find Some Trails
deltaR50 replied to Blevinger's topic in New People Start Here!
nice truck! hey what kind of roof basket you running? im looking into that as for my next upgrade on my r50. thanks!
