8
Everything posted by CNAM
Electric cooling fan and thermostat control wiring kit coming thurs! I'll post pics when I do the the install!
Adios p1320 and p0304! Changed out ignition coil on cylinder 4 last night.. Was getting p1320 Primary Ignition Misfire and p0304.. Cyl#4 Misfire. Of corse the most difficult one to replace. Under the throttle body and behind the air intake we go!! Reste the eheck engine light and keeping fingers crossed. Hope I dont get any more misfires although I've only got three more coils to change if I do. #onebyone # proccessofelimination LOL
Found fabricator for custom upper and lower trailing arms for lifted pathys..
To GoPro or not to GoPro?.. Is NOT the question...GoPro vids coming soon!
Sway bars..? Keep 'em or Ditch 'em??? or make Disconnects?
4" sub frame drop this weekend!! Plus new control arms, Warn locking hubs, ball joints and tie rod ends! WootWoot!!
Warn manual locking hubs vs. Stock auto lockers for the 2001 R50..? Any comments or suggestions? Are they worth spending the cash on them and having to get out to lock up the front?
Im by no means an expert here, all my knowledge is coming from reading posts in the forum when I was making the same decision for my 95. From what I understand the 2001 has drive flanges instead of auto hubs, which act like locked hubs 100% of the time. By installing the manuals you wouldnt be spinning your cv's all the time which will give you a little less rolling resistance and maybe a tiny mpg gain. More importantly it will reduce wear on the cv's lengthening their life which i...
So this afternoon I plan on changing out my front sway bar end links and sway bar frame bushings. I have been hearing some unpleasant sounds from the front (as well as the rear) rattling, clanking, metal 2 metal, popping... etc. Looks like the replacements are easy to DIY..? Any thoughts, comments or suggestions. Is this as straight forward as it seems to be? Is there anything I should be aware of before starting? Do I need to adjust the camber of the front wheels as part of this repair? Wil...
