Everything posted by fman
Howdy It bolts to the heat shield on the exhaust if you have stock manifolds, if you have extractors it needs to go on the head somewhere
might be worth running a multi meter over the leads and check for any resistance issues ie cracks or breaks in the leads, maybe maf related as well
still plenty of both wd21 and r50 on the road here but they are slowly going, mostly i think mostly due to the auto's dying most arn't willing to fork out the $ for a rebuild and it helps South Australia has historically had the oldest fleet of cars in Aus, generally good for rust too
Basil Fawlty rang in ...Manuel, is late for his shift
i used a 50/50 mix mineral turps/ boiled linseed oil mix... works great it forms a hard shell after a few coats, heeeeeaps cheaper the painting and probably will last longer also great on older metal and paint i used to splash it on old utes tractors etc, one advantage is it keeps the grain look of the plastic it will turn whites dull brown though no issues on black one big caveat though dont leave oiled rags brushes etc in piles or you will have a fire it puts out a lot of chemical heat
illd look at a new fuel filter first then give maf a clean as a start
Pulleys for VG30E accessories on a VG33E engine
fman replied to Dizer92Pathfinder's topic in 90-95 WD21 Pathfinders
from memory we here in aus had vg30e in the navara d22 untill 02 or 03 -
my old wd21 did that turned out to be a dud tps prolly worth checking the connector and harness etc
new cap , rotor, a/c idler pulley bearing and leads
these guys do one http://www.formulaoffroad.com.au/index.php/component/jsautoz/searchresults one on gumtree here http://www.gumtree.com.au/s-ad/loganholme/other-parts-accessories/bull-bar-pathfinder-93/1058016736
awesome cheers
sorry for the thread jack but my 6/93 has receipts for a timing belt change from late 2007 its got 40000 km to go b4 its due for change. should i get it done on age alone or leave it alone untill its due currently 259000 km on it. full dealer service history came with it cheers
give wholesale autos (http://www.automatictransmission.com.au/askorto.asp) a ring in melb they have everything for our autos including a hd upgrade kit quite exy though
i took his question as fitment question, prolly should have put a smillie in there have beer and calm down terrano
nope not reliant on gravity you take the console surround off then the center vent out and it bolts up thru the dash there is even a 12v lead there already well there was in my old 92 at least there is also a modern alternative as well a small android tablet or phone with an Clinometer with Compass package(https://play.google.com/store/apps/details?id=com.brainlab.tiltmeter&hl=en) works well.
its generally worth testing new/old thermostats in a old electic fry pan fill up with water and set to heat up to needed temp and with a temp probe and wait to see when /if opens then turn off and wait to see when it closes if its in spec all good if not try another till you get a good one.
good to hear
you tube will be your friend search paint and prep https://www.youtube.com/channel/UCdCViyboSXSfns8wtFx3_1g
blue2 has 244500km at present
went to the local u pull it they had a fresh 88 pathy and a 93 v6 navara got some rola roof rack parts and a long range fuel tank looks to be about 150 ltrs or so off the 88 and a complete upper plenum and carbon filter, off the vg30e all for 100 bucks nice getting filthy on sunday morning blue2 got a full service and new head and ecu temp sensors, thermostat & new lower hose
some times you will find the impeller clogs with crap and possibly silicone in your case ;P i found a small bit of pine needle had slowed mine down.
1993 Pathfinder - What now? Very low idle all of a sudden.
fman replied to MrEviLDeD's topic in 90-95 WD21 Pathfinders
yep check the fuel pressure regulator vac line on the back end of the plenum mine rotted off and caused the same miss behavior -
i ended up using 800g wet sandpaper and alot of time that glue was some nasty stuff..
