stalker
Everything posted by stalker
  1. I've done it in all those areas...well worth the money to do it...
  2. You like that flex ramp...should have seen the neighbors glaring at us..
  3. I am trying to make a run at Path of the Year.! one of my Wheeling buds Cherokee
  4. here is a couple little text flexing going on...need to move the front shock hoops up higher...the shocks are bottoming out...but it will be an easy fix for that
  5. here it is...i know its ugly..it will all be plated in so no water or mud will get in there
  6. i will take some pictures later today if i get a chance
  7. i can show you a picture before its finished if you like.? i still need to weld in some plate and then it will be finished
  8. Good eye TME...those are already cut off...had one of the guys at a local 4x4 shop weld those on because I've been so busy working...long story short. thats not the only thing he F up...just waiting for the new ones to get in...I was using the factory uppers for the rear but now I am going to make a custom upper mounts so I can move the shocks up higher and angle them in a little more...
  9. those are getting chopped off and put up higher for a better angle...you can order those same hoops from TG
  10. still waiting for my drivelines to be finished but here is how it looks for now...
  11. measure eye to eye and then you can determine what you can use to replace them
  12. Me and a few friends been wanting to go check out browns runs...I hit you up for sure
  13. Those are used 38's but they only measure to 36.5"...picked them up for cheap on CL to mock up the build and use during summer. I will be running either 37x12 Rockers or 37x13 Boggers when muddin season comes back around.
  14. this will be about 3 to 4 inches shorter...looks way tall... you can get away with fender flares instead of using those ugly flaps
  15. thanks Nismo...looks like things will be just fine...just had to add adjust a few things around... Here is a few more pictures
  16. face palm...lol We did take a lot of measurements and mocked up the axle and springs before completely welding it up the hanger...but now that i think about it...i should have waited for everything being at complete mock...
  17. Front Nismo Hanger is welded on and painted...ill get some better angle pictures this will be up for sale..
