Slartibartfast
  1. If it's not isolated to the headlights, then tracing the headlight circuit might be less useful than I hoped. I would expect the alt to struggle more with the lights on than it does with them off, but I'd be curious to see battery voltage at idle, loaded and unloaded, when it's acting up vs when it's not. Was your defroster on when you heard it idle up on its own? The auto HVAC system kicks in the aircon when the defroster's running to dehumidify the air. Could be the compressor cycled and that's what made it idle up. It's been a while since I had working aircon in mine, so I don't remember how much it's supposed to idle up for that, but I don't think it was that high. I don't think the manual HVAC does that.
  2. That's a weird one. I've had low idle/stalling issues with mine when the MAF connector was acting up, but I've never had it stick on high idle. And the headlights playing into it is bizarre. There is an adjustment on the IACV, and the procedure to adjust it is in the service manual. If you think it's acting up because the last guy messed with it, it might be worth ruling out. The crosstalk with the headlights tells me something else is wrong. Adjusting it to mask the current issue may complicate your diagnosis of what's actually wrong, or give you other issues. For some damn reason, these have two idle control valves. The IACV-AAC (the one under the back of the intake, with the adjustment screw) has a solenoid that's pulsed by the computer to fine-tune the idle. The IACV Air Regulator (the tall one behind the EGR, with the plug on top) is wired to the fuel pump relay and acts like the electric choke on a carburetor, except backwards (starts wide open for high idle on cold starts and slowly closes as it heats up). Test info for the two valves is on EF&EC 117 and 119 of the '95 manual. I suspect the valves themselves are alright, but a weak connection in the headlight circuit is confusing one of the sensors that tells the computer when it needs to raise the idle. The computer controls the IACV-AAC according to input from the sensor in the dizzy (which tells it the engine speed--you'd have other symptoms if this was bad), coolant temp sensor (idles up when it's cold--check the sensor and its connector), ignition switch (start signal, doubt that's got anything to do with it), throttle position (presumably so it's not thinking about idling when it's not idling--it is idling, so I doubt it's this, though it wouldn't hurt to check its adjustment), neutral position switch if it's an automatic, aircon switch (idles up when the aircon is on), power steering pressure switch (idles up when the power steering is working hard), battery voltage (I assume so it can idle up if the alty needs more RPM to hit its voltage target), and the vehicle speed sensor (I assume this is so it can work out if you're coasting or engine braking). If the valves themselves check out, I would go to the EL section, work out which fuse link and ground point the headlights use, and check them both. If any of those points are shared with other equipment, and are poorly connected, power could be backfeeding all over the place. Make sure the connections are clean and tight and the fuse links are in good shape. If that doesn't get you anywhere, I would check the sensors that tell the computer to raise the idle (EF&EC should have test info for each) and their connectors. Failing that, check the battery voltage at idle (with the headlights on and off), check the engine grounding (voltage from the engine to the negative post on the battery should be pretty low), check the other fuse links, and check whatever other ground points you can find. Look for any obvious harness damage. Wiggle stuff with it running, see if you can find something that changes the idle. Hell, check the vacuum lines, if you haven't, though I doubt they have anything to do with this. The '95 manual also has some basic troubleshooting, including various idle issues, starting on EF&EC-50. When it's at low idle (with the headlights on), does engaging the aircon or the steering switch (turn full against the stop and hold it) bump the idle back up? Does it idle down for just the parking lights, only low beams, only high beams, some combination thereof? And finally, does loading the electrical system with something else (rear defroster, blower motor, something like that) have the same effect?
  3. I think you're overestimating the current draw of the aircon clutch. I can't find a spec for yours specifically, but it looks like aircon clutches generally take less than 5A. If your relay was happy switching two 55W halogen fog lights, it should have no trouble with the compressor clutch. If some blue relays were heavier-duty than others, and would cause issues if switched, I would expect the service manual to call that out somewhere. It doesn't, at least not that I've found. It just calls them Type 1M. Looks like there are at least three different pin layouts (two in the '03 manual, one in the '95), so that may explain a few of the different part numbers. Other than that, could be different suppliers, slight revisions, something along those lines. Hopefully an R50 owner can get you the PN off of theirs to put your mind at ease.
  4. I don't have an R50 to check, but nissanpartsdeal shows the aircon relay as 25230-79915 or 25230-79945 for an '03. Both say they were replaced by 25230-79917.
  5. No more binding! I didn't have to remove much, basically just chamfered the upper edge of the hole on the bench grinder. It took longer to clean the grit out of the sockets afterwards than it did to modify them. RE the springs, I have a set in my parts truck that I'm going to try first. I thought they were lift springs, but I'm beginning to suspect they're just new stock springs, which look like lift springs in comparison. If I decide I need more, I may have to check out those OMEs, thanks for the PN. I'm only 6'3 or so, maybe 6'4" with my shoes on, but yeah, being tall is overrated. Lots of crap to walk into up here.
  6. Now that you mention back-seat passengers, I do vaguely remember hearing something scrape on a "shortcut" I took, followed by my friend in the back complaining that he'd hit the headliner. Collapsed springs may explain a few things about this truck. Speaking of hitting heads on things, I installed the new struts today, and I'm loving the difference. The bottom corner is up by 7 3/8", and I can walk under the hatch without hitting my head on anything. I am well clear of that damn corner, which is worth the cost on its own. I only clear the plastic trim by an inch or two, but if I get another 2-3" from fixing the suspension, that'll be plenty. The only problem I've run into is that the ends on the struts have a little less range of motion than the old ones, and I guess the angles are a little funny on the upper ball stud mounts, because the top joints ran out of travel before the bottoms were in position. I was able push them the rest of the way without obviously bending anything, but, yeah, that ain't right. I'll go in later and see if I can file a little clearance into them. If that doesn't work, the ends are just screwed onto the struts, so they should be easy to swap out. Maybe the plastic ends have more range of motion. That would make sense--I ordered the metal ends thinking they couldn't go wrong, so of course they'd be the one thing that did. I used SE244P110S10-W (x2) from liftsupportsdepot.com. Side note, that rear hatch is a heavy bastard.
  7. IIRC Nefarious (Ekim Naelcm on the FB page) had to screw around with timing on his TD27. Might drop him a line, though I can't say I've seen him post in a while. I tried to find his post (to make sure I was remembering properly) but of course Facebook is a steaming pile of algorithm and couldn't find its own ass if it had one.
  8. Those look simple enough to build, and pretty solid, too.
  9. Wrecking yard, or maybe someone has their old one on the shelf.
  10. No worries, hope it's actually that simple once you get into it!
  11. Control arm bushings would explain the wobbly feeling. Bottoming out sounds like shocks or springs. If the ride height is OK, I'd start with shocks. I put KYB Excel-G shocks on mine and they haven't given me trouble.
  12. I think I've found a winner! They're 1.3" taller than the ones I've got now, which doesn't sound like much until you factor in the leverage. If my math is correct, that should bring the bottom of the hatch up another 7.8", plus whatever I get from fixing the suspension. When all's said and done I might be able to walk under this thing with a hat on. That's probably a weird thing to be excited about, but here we are. I've ordered a set and will post the part number if they work as well as I hope they will.
  13. That's a good question. I haven't heard mine bottom out, but I had a look under it, and I'm guessing it's supposed to have more than 1" between the rear axle and the bumpstop. The parts truck has more like 3.5". I need to get that thing stripped before snow anyway, and those should be easy enough to snag. And yeah, I've got the aftermarket clip-on struts on mine already, so most struts should just pop on. I looked through what Princess had online, and, again, found just larger and just smaller than what I'm after--thanks for the idea though. I'll keep poking around, maybe some manufacturer's got the oddball I'm looking for.
  14. Has anyone found a longer lift strut for the rear hatch of a WD21? I'm fairly tall, Rat Trap's rear springs are stock/original, and I work out of the back a lot, so I hit my head on the rear hatch regularly. Usually it's just the plastic part, but once or twice I've caught my temple on that bottom corner, and I do not want to do that again. My current solution involves walking around like Marty Feldman any time the hatch is open, which is hard on my back, and doesn't always work. What I'd like to do is make the hatch open farther. With the gas struts removed, I got about 10" more travel (measured at the bottom corner) before the hinges/roof topped out (I didn't check to see what actually hit). I took a few measurements and it looks like I can get roughly 3" at the corner for every 1/2" I can add to the struts. Of course the hatch still needs to close, and longer struts are also longer when compressed, so I can only take this so far. The standard struts do not appear to be fully compressed when the hatch is shut, so I think I've got a little leeway to work with. I considered moving the lower pivots up the pillar, to use however much compression is left in the standard struts, but I don't see a way to do that without butchering the pillars, so I'm hoping to find a slightly longer lift strut instead. I dug around on Rockauto, but didn't find a winner. I found a few that are dimensionally close to what I'm after, but their strength numbers are way off (factory replacements are around 110lbs, so I don't trust 90, but 202 would probably break something). I also found a place that makes custom struts, but naturally they're 4-5x the cost of the off-the-shelf OE-replacements. It does occur to me that a suspension lift would also raise the hatch relative to my head. Lifting the truck just to get the hatch out of my face is not my first choice, but it is an option, and my parts car does have lift springs on it. I'm hoping for a simple solution that doesn't involve a helmet or an angle grinder. Anyone else had/solved this problem?
  15. At least it's mostly fixed! The transfer is mounted on rubber, so, yeah, it should have a little wiggle to it. Not sure what you mean by lateral play--is it axial (moving parallel to the shaft) or radial (moving at 90 degrees to the shaft)? In either case, AFAIK those bearings aren't preloaded like wheel bearings, so I wouldn't expect them to be perfectly tight anyway. If it isn't loose enough to trash the seal I doubt it's an issue. There might be a spec in the service manual for allowable play. The CV runout is an odd one. I don't know that it's an issue, but I would not have expected a CV to do that, at least not enough that you'd notice it by eye.
  16. My diesel knowledge is (still!) similarly limited, but I would add checking the water separator if you haven't. Pull a fuel sample while you're at it and look for algae or other goo. Might be worth blocking the EGR to see if that helps--if it's easy to get to, it's an easy thing to rule out. I would not be surprised if the rebuilt pump needed some timing or other adjustment. I have not studied it but do have a copy of the TD27 engine service manual on Dropbox, if that helps (I don't remember where I found it or I'd link you there instead). The place that rebuilt the pump might have some ideas, too. And yeah, get some fresh fuel in there before you try too hard to dial it in.
  17. No worries man! I was kind of surprised the clip was available on its own--more surprised that the temp selector is too! Good luck and let us know how it goes.
  18. Ah, so the clip's missing and the cable sheath is moving around. If you can't find it in the carpet, NissanPartsDeal shows (what I assume is) the correct part as 0922-50410 (snap ring). Not available there, looks like these guys have it though. Neither has an actual photo of it, but from the description, I'll bet an E clip with an ID a little smaller than the cable sheath's OD, thin enough to slide into that groove in the housing, would do the job (or that's exactly what the OE part is, just marked up). Worst case I guess you could just JB Weld the sheath in place with the bite marks lined up to the groove and hope you never have to take it apart again. Looking into it further, looks like the non-aircon models had the cable, and the aircon models had the pot/servo arrangement. And yeah, that pot is where I'd start too, assuming the mechanism checks out (slider goes from end to end when you turn the knob). I'd check those solder joints on the off chance one's cracked, and shoot some contact cleaner into the pot and work it around in case it's just got some trash in it that's preventing a wiper from making contact. (And, yeah, check it with the meter to make sure the resistance rises and falls smoothly and the trace isn't broken.) If the pot is buggered, you might get lucky and track down a new pot using the part numbers stamped into the case, though that's probably a long shot. I guess if you don't mind channeling Red Green, you could work out what its resistance is supposed to be (hopefully its resistance is labelled, or you can find a datasheet from the other numbers on the case), gut the mechanism, and install a standard rotary pot through the face plate. I wouldn't worry too much about the cable wearing through the sheath. It shouldn't have much load on it. Wouldn't hurt to shoot some silicone spray down the sheath while it's apart, though.
  19. Try the HA section in the service manual. Free download from Nicoclub and worth having anyway. I had a look at the '97 manual (because that's what's on my hard drive) and there's a bit about the cables on HA-52. There's a lot of troubleshooting in there, most of it electrical/aircon related, but there is a section for the manual HVAC. The vent direction sounds like something's mechanically busted. Hopefully the head unit, or the cable's come off, though the tight spot could be something that's fallen down a defrost vent and bound up the mechanism. If nothing jumps out at you, I'd remove the cable from the HVAC head and see if pushing and pulling the cable manually makes the vents work. If it does, it's the head. If it doesn't, either it's come off the blend door, or the blend door is buggered. The temp is an odd one. Again, hopefully a fault in the head/cable and not a blend door. There's a valve that's supposed to shut off the coolant to the heater core when it's set to fresh air, doesn't sound like that's working.
  20. Looks like the seller got what he wanted for it!
  21. Again, I don't know crap about the R52, but from what I've read they "judder" before they let go. Probably a good call selling it before that goes--I have not heard good things about Nissan's CVTs. Recently I helped replace the rear wheel bearings in a friend's Honda. The howling noise went away, but now that one noise is gone, we can hear all the other stuff that's worn out.
  22. Unless it's easy to get to, or you have a good reason not to trust the old one, or you're in there for something else anyway, I'd probably leave it on the shelf.
  23. Based on the cartoon in the manual, I still think it's dragging the clutch to transmit only as much torque as it thinks it needs to. Think of it like brakes--they're not just on or off. Slipping a clutch like that does seem a little abusive, but automatic transmissions slip a little whenever they grab a gear (or they'd slam you around), and the clutches in a limited slip diff are slipping any time you're not going dead straight. They're built to take it, and also they're not slipping all that fast, or for all that long. In normal operation, I would not expect the transfer case clutch to have to slip all that much, either. If the system kicks in quick enough in response to wheel slip, there won't be that much speed difference to correct for, and the slippage when cornering shouldn't be much either (similar to how it's not enough to activate the viscous coupling). Driving down the road with mismatched tires may be a different story, if the transfer gets confused and drags the clutch for miles on end trying to correct what it would see as wheel slip. Hopefully the same code that makes the computer pissy about manual hubs would catch on to what was happening and release the clutch before it burned itself out--or the operator would know enough to not leave it in auto mode when running an undersized spare. I imagine the computer is pulse width modulating the solenoid (cycling it on and off faster than the clutch can react to, while varying the length of the 'on' pulses) to dial in whatever pressure it wants. (IIRC this is also how the automatic transmission controls its line pressure.) If it was just stabbing the clutch to full lock, letting off to see if that fixed the slip condition, then stabbing it again if it didn't, I would expect the truck to shudder like the ABS was kicking in. I have no personal experience with this box, so I'm mostly speculating here--as are the people in the thread you linked. If you want to take a deep drive into how this critter operates, the TF section in the service manual is your best and probably only source of accurate information, short of dissecting yours to see what makes it tick, or datalogging the solenoid in action. My old TX10A may be clunky and primitive, but it sure is easier to understand!
  24. Wet clutches are controllable, viscous couplings are not. Viscous couplings are just a stack of plates with thick oil between them that makes it hard for them to move one independent of the other. Half of the plates go to the input, half to the output, alternating, so when the coupling is forced to slip, all the oil across all the surface area of each of the plates (except the two on the ends) fights it. The wiki writeup on them says the oil gets thicker the more it heats up, so the more you beat on it and force it to slip, the harder it fights back. It's got enough slip to avoid torque bind, but it fights back enough to put power down when you need it. It has no external controls. A wet clutch is more like the clutch in a manual transmission vehicle (except that it's soaked with oil). An external force (in this case fluid pressure on a piston, supplied by the pumps, controlled by the computer) clamps the plates together, causing friction between them. Clamp them hard enough and they don't slip at all. It's the same tech that grabs gears in automatic transmissions, and I think it's common in motorbikes and quads, too. Usually they've got a bunch of plates, like the multiplate clutches used in some sports cars, though the exploded diagram for the ATX14A shows a smaller number of plates than I would've expected. Technically the wet clutch could slip when clamped completely up, same as a dry clutch, but I imagine you'd have to hit it pretty damn hard to break the static friction unless it was wore slap out or you were hitting it with way more power than it was designed to take. AFAIK auto mode won't lock the clutch completely, so no, it shouldn't torque-bind if you're gassing it through a corner. The viscous is a far simpler solution, but I imagine it did not play well with the ABS/traction control, or Nissan didn't like its road manners (might be more prone to understeer). The computer-controlled-clutch solution meant they could make it behave however they wanted. I've seen similar computer-controlled wet-clutch transfers in domestics of the same era (BW4405 in an Exploder, NP236 in an S10 Blazer), so it wasn't just a Nissan thing. That is a lot for a filter. If you haven't, google the Nissan part #--if that quote came from a dealer, you may find it cheaper online. If it's like the filter for the trans, it may be more of a screen than a filter, and easy enough to clean out. Worst case, I imagine the transfer case would have to be absolutely shredded to shed enough material to clog the filter. New fluid is a good idea, though. Did a world of good for the TX10A in my '95. Make sure you get the right stuff!
