ChromoTech
Everything posted by ChromoTech
  1. Is there really an amp behind the deck? ive never really checked back there. mine is a 95 so it might be different (maybe)
  2. it really sucks when you get to the rear speakers(roof mounted versions) cuz if you try to use 5x7s you cant get the speaker covers back on then your new speakers are prone to getting punched out (anyone know a way to make 5x7s fit flush to get the covers back on, send them this way)! and for the fronts i just cut out the back of the basket thing and i used insalation(?) tape to seal up the small gap between the basket and the back of the cone. I used the tape for the rear too for the same reason. -alcohol-
  3. Its still a very cheap way to go. kinda easy too
  4. oh i got those replaced earlier mine were pritty bad too they were warren into the metal.
  5. Just tap the broken stud and drill it out you may have to remove the manifold to get a good look at it.
  6. I also found these which look good. http://www.jcwhitney.com/autoparts/Product...modelId-5001571
  7. yesterday i was in auto zone and i found a cool little thing Air Flow Sensor Adapter http://www.bomzracing.com/index.asp?PageAc...PROD&ProdID=655 its was only $5.00 though! doesnt that work just like jims way?
  8. And if it is the original cooler you need to get a new radiator style cooler that fits infront of your engine radiator.
  9. what is the compression rod?? isnt it part of the steering?
  10. Would these fit?? http://www.cardomain.com/item/PILHB360C they look close to the stock fog lights cheaper places to go? than this?
  11. I got some nice chrome 15x8 rims for $55 a rim at Discount Tire Co.
  12. Nissan has a 100,000 mile free replacement policy for the defective manifolds but most of the time only the studs are broke so the manifolds dont have to be replaced they just replace them with better quality studs and replace the exhaust gasket. If yours has over 100k miles thay wont honor the policy. My 95 has 128,000 miles and just getting 2 new studs replaced cost me alittle over 200 dollars! Now I have another leak forming some where so im just gonna say screw the manifolds and there crapy studs, im going with headers! around $200 for pacesetters (eeegh) but there better than the manifolds.
  13. I think when I get my suspension lift on im gonna run 32x11.5 15 could i run those on 15x8 rims? or would i have to run 32x10.5 15 instead? btw im gonna go with a 4in. lift
  14. ChromoTech
    OOOPS
    I just drive too hard to not have the stablizer bars off. take a corner and you feel like your gonna flip!
  15. I think when i order that filter im going to make a bracket out of the air box supports for it.
  16. Everyone is ok, but my friend is going to be paying for it for a loooong time!!
  17. yea that was not very smart at all my whole group thinks that his last name fits him perfectly Mike RISK
  18. Cant you replace just the pads or do you have to get new drums too
  19. that weld probably is for the threads going into the pipe for the sensor to screw into.
  20. How hard is it to work on the drums?? mine sux!
  21. ChromoTech
    OOOPS
    hahahahahaha!!! I tried having the swaybar off in the rear and i hated it. boucing from side to side
  22. Just drop a good old 90-95 Nissan 3.0 mutiport fuel injected engine in there. be careful with that 4.3 engine!! my brother has a 1995 GMC Jimmy with the 4.3 Vortech engine and one of the main freeze plugs is about to blow and it has a rod in the 3rd cylinder knocking at only 77,000 miles. my brother hates the truck with a passion and he wishes he never bought it! parts he has replaced; ac compressor suspension(both of the front shocks bottom bolts were busted off) fuel pump ECU timing belt ive driven the truck and i see what he means. It handles like a caddy and it has no balls whatsoever. the tranny sux even worse than mine! it shudders and clunks along. CHEVY :oops: chevy -argue- Nissan
  23. Is the air filter rechargable?like K&N filters or do you have to buy new filters. and could you use the K&N recharge kit on that filter? how much was the total price with shipping and tax? right now i have the K&N pannel filter rigged up with some wire and some tape I took half the filter box off and wired and taped it so i have the same affect as if i had the cone filter.(its only gonna be that way untill i order the cone filter) PS: I like your support for the intake
  24. ChromoTech
    Intake
    I found this on the AC websight http://www.4x4parts.com/public_html/shop/i...a8965c9bd7de817 Does anyone know if these work??
