Everything posted by ChromoTech
I guess Im just a dedicated Pathfinder owner
WELL anyone? it seems easy but im not sure about it
how much do new rotors or drum breaks usually cost??
Is there any way to mess with the stock fog lights to make them run w/o the headlights on. or to make them run with the high beams on???
Hey mike how much for the computer is that the ecu or somthing else?
Yup mine did the same thing i also found out my local repair shop ripped me off! during the time when they put in my new water pump they stabbed two holes in my radiator and tried to cover it up by addind a bunch of that crappy radiator stop leak now i have a nice steal and brass radiator in there at their cost hehehe compared to the original plastic and aluminum one. Question: how do you replace the thermostat??? anyone have problems with blowing oil seals/gaskets after installing a water pump?
I wish I did as good as you did on the fenders! i used a sawsall on mine
Lately my Pathfinder has been smelling like rotten eggs when i drive it at highway speeds :oops: :X could my cat be clogged? if so any ideas on how to solve this problem?
u could also try www.autopartsperformance.com they are good
Changing the Solinoids in a 93 Pathfinder with AT
ChromoTech replied to a topic in 90-95 WD21 Pathfinders
I reset my tranny computer and ive not had any problems since and changing my fluid and filter took like 4 1/2 hrs and i was also covered by tranny fluid! :oops: -
Dont run 32s w/o a lift! mine tore up my fenders i need to jack up my torsion bars a bit would that help me any?
Sheesh i replaced my idler pulley and it didnt cost that much! it was only like $15 and a 10-15 job
I hate when my power switch comes on! it does it all the time whan im driving:)
My timming belt makes a simmilar noize as a bad bearing makes. like a whiring noize when i gas it alittle. (new belt)
Does yours do that too?? one time i mistaked the noize for one of my rear tires going flat:)
I need to get the whole front end of my truck redone! all of my bushings are rotten! and my lower ball jonts are leaking grease! HELP I also noticed that my 32x11.5R15 tires have bent up my fenders
Man thanks for the pics my throttle body was all gummed up i used almost a whole can of cleaner in that thing! THANKS
My fuel pump has been making hissing noizes. is that a sign of it going bad??
Man ive been rubbing with my 32s and its been tearing the crap out of my Bfgoodrich all-terrains
how to send jim pics of your Pathfinder ?
ChromoTech replied to ChromoTech's topic in New People Start Here!
THANKS -
I have one that i might sell to you off of my 95 Pathfinder $35. Good?? its in great shape. I live in arizona
Send me info!
