Pathy
    I JUST BOUGHT IT, LEATHER SEATS!!!!!! w00t
Pathy's Achievements
  1. SO i was just driven normally when my brake light and a/t light came on, so i didnt think anything of it and then i looked down and my temp guage was maxed out. I thought it had to be a malfunction an electrical problem or something but i was wrong, before i could get home lots of steam came out my radiator resvior. Kinda of freaked me out, any suggestions. I just replaced the cluth fan and all hoses 4 months ago.
  2. Pathy
    Two problems
    When ever i roll off the curb of my drive way or go over a speed bump at regular speed, i hear a huge grinding noise coming from the front left tire. I checked to make sure the tire wasnt rubbing the fender and thats not it, also when i bounce that corner by pushing down on it, it doesnt make any sound at all. Im trying to figure out if its a bushing or something like that. Second problem is a lot of sqeaky noises coming from the fan belt area, i cant really pin point it, would replacing the fan belt maybe fix this?
  3. Thanks guys, i didnt know how easy it was to check the ecu, turns out to be that stupid o2 sensor, well i feel better now that i know.
  4. would a temporary vacuum leak cause the ecu to mess up everything? cuz the seal on my intake blew so i pulled over and duck taped it, then it was fine after that.
  5. My engine light has been coming on, on and off for 2 months, i have a perfectly fine idle, but sometimes after it warms up the acceleration feels a little sluggish but even when it warms up it is still a perfectly fine idle, im leaning toward o2 senser correct me if im wrong.
  6. i just used longer screws on the door, and even though speaker didnt fit into that plastic holder thing i just screwed the speaker into it, and it fit perfectly back into the door, dynamate is a must around the inside of the plastic part that touches the speaker.
  7. This might be a extremely stupid question but is the stock at cooler external or internal, im trying to figure out if mine is aftermarket or stock, its pretty lengthy and long, ive only had my Pathfinder for 4 months so i dont know what the previous owner did, and also it supposively has 144,000 on the orignal
  8. Did u use the thermal seal on the broken stud? Does it like dry inbetween the gap the stud makes, ide like to know more about this keep me posted on u did it.
  9. ive had a passenger side manifold leak for about a month now, my question is... My leak goes away after about 2 to 5 min of driving, does that mean it is a crack in the manifold or does that mean its a broken stud, or possibly both, or on the rare occasion a gasket inbetween the y pipe
  10. my auto pathy shifts from 1-2 at about 2800 and from 2nd to 3rd at 3000 plus even under light accel, any toughts?
  11. why are u using 93 octane in the first place, i use the lowest grade, is that bad or something
  12. is that highway or town driving? cuz i mostly do all town driving and get bout 240-260 with my stock pathy.
  13. Well i decided to do something about it so i went to the local autozone got my self a fail safe t-stat and a brand new fan clutch and new upper and lower hoses, put them in today, took her out for a ride and the temp didnt even nearly reach pass the half point with A/C on and beating the heck out of the gas pedal, and now when the fan engages it sounds like an airplane. Thank god that was a quick fix.
  14. after driving around intl fully warmed up, when u turn off the engine shouldnt the clutch fan still be engaged mine spins freely after driving around with it supposively engaged.
  15. Could it be time for a new radiator, do u still have ure orginal one?
