NWT87PATHY
Everything posted by NWT87PATHY
  1. Hell yah, bowtie running gear just can't be beat!. Plus the iffy front end will maintain stockish appearance. Still up in the air if I should put a 4 link in DA back or keep her on the leafs
  2. Ahh nice u retro'd the stock computer's from the chevy. Should try something like mega squirt+mega shift to really unleash the beast! Sent from my iPhone using Tapatalk
  3. Weird my 87 can run with out any vac lines hooked up? Sent from my iPhone using Tapatalk
  4. What are you using for computers? Retro fit stock stuff or stand alone? Sent from my iPhone using Tapatalk
  5. Is it staving for fuel? Fuel pumps can be a cruel mistress. Sent from my iPhone using Tapatalk
  6. Better to build then to find aftermarket bolt-on. IMO
  7. I got 04 gmc truck mats in mine they fit decently and they got checker plate look! Sent from my iPhone using Tapatalk
  8. Treat it like a tbi maybe you will have better luck. Make sure u have iac and your injectors are spraying properly, perhaps give it a tune up and make sure your fuel filter flow is going the right way Sent from my iPhone using Tapatalk
  9. You bet their is! Expect to break Off a few of the screws and more then likely do some rust repair around the hole.
  10. You bet their is! Expect to break Off a few of the screws and more then likely do some rust repair around the hole.
  11. you bet! i did the front crank seal in my 87 3l. while i had it apart i put new cam seals, water pump, timing belt and thermostat. this 07 that needs a timing chain replacement has around 180k, so just the timing kit and be done with it?
  12. What else should be changed while i have it apart?
  13. my bad i dident see the whole post on my phone. Only GL-4 goes in the 5speed's
  14. Not lambo doors, but still pimpin Got rid of the ducting.. Eye balled the parts.hmmmm.. Dosent fit..Hack chop cut. Allmost their! Little bit of some wiring.. And a coffee
  15. Totaly agreed lambo doors are kind of hoaky. The apprent reason the door has to swing out is so it will clear the cab.. It seems to me you pull it past the fulcrum and the struts take over lifting up. It's allmost impssible to rotate a square inside a square! The fail safe for the shaved door's is the hatch. I will disable the lock so i can not lock myself out! No real security issues were im at ( key is in the ignition 99.9% of the time) lol. The ultrastart comand start i use supports upto 3 FOB's so if i loose one i allways got a spare!
  16. for sure! but i just gotta do the lambos! the shaved handle's are gonna be a easy one, Im gonna take the passenger side lock solenoid from my donor door and fashion it up to the door latch on driver's side and since everything on the passenger is their i just need to do the fancy coat hanger bending. Then when I get all that done i hook it up to a command start and the FOB opens the doors spring loaded style.
  17. http://www.car-parts-accessory.com/Lambo+Door+Kits/Universal+Lambo+Door+Kit+90+Degree/3/
