4X4pathy94
Everything posted by 4X4pathy94
  1. Make sure the front of the truck is level aswell... By adjusting torsion bars if need be.
  2. I spliced a relay into mine aswell and it works... If you travel through alot of water crossings with your pathfinder you should look into using a water proof relay, because the relay will short. Happened to me on the trail, now i have a rubber over it lol.....
  3. @ahardbody That hwole rebuilt starter thing happend to em as well went through 3 starters before coming to one that is working right.
  4. In my 94 the safety switch is a lil off canter when replacing my old transmission, I just push up the shifter all the way up in park pushing in the button aswell and she starts..... also try in neutral pushing forward or back to see if that helps...... There is also a thread on adding a relay to the system on here somewhere that helps with the clicking and makes the starter turn over quicker, if it isn't the safety switch you can try that.
  5. lol.. Mine is doing something like that only mine is stuck completly on high heat.. i can choose through the low mid high settings but that is it. I havent done any tinkering with it yet but i will have to soon before the heat waves get here.
  6. Adam sell me some more of that hash sooooo good
  7. Yes, the starter did exactly that to me but didn't affect the flywheel. I replaced with another rebuilt and this one seems to be alright.
  8. Adam your a crackhead............ doin all those drugs you do
  9. Adam how was that dope last night.... High as kite you were funtimes
  10. Love it, I really want to do an SAS on my truck bad..... great pics
  11. I think it could ignition wires or distributor cap or even both..... Perhaps the the electrodes are worn down allowing for early morning dampness to screw things up. I think some where on this tells you how to check them. Oh and welcome NPORA
  12. Because i have the sunroof I'm probably gonna delete the two brackets in the middle of the rack seeing as does not fit correctly, and i can not bring the rails closer together for it will interfere with the sunroof. I like the look of the plexiglass and will look into it.
  13. Yea that last one was done really well and he didnt have a sunroof which makes it easier for this instll.
  14. Oh i knew i wasnt going to be the first to have this done, i actualy got my idea from the red pathy you have in that pic. All i knew is that i wanted a roof rack and i found that one. My sunroof is still able to open,and i have trimmed eberything to fit flat. Now the middle feet or bracket does hang out a bit maybe 1/2 both sides. Havent figured out away to fix this may just add a piece underneathe to make it look for proper. I like it with the flaring myself i haven't trimmed it yet and i know i could make it fit better but i havent bolted it on either yet. I also havent figured exactly how i was going to bolt either self tapping screws or maybe even bolt it, but then i would be taking the insde apart...
  15. Which pics do you think are better? With wind flaring: And without the wind flaring: Picked it up at the local J/Y for $150 thought it was a prett good deal, and i needed a rack!! What do you guys think?
  16. You also have to calibrate the shifter cable when you attach it to the new tranny..... Umm did you put in your torque convertor bolts?? lol
  17. ADAM ARE YOU HIGH AGAIN
    ALWAYS HIGH
  18. adam are you HIGH again
  19. alright good to know bc im gonna be putting in the jgc coils tomorrow and dont want to have to spend 15 bucks on a coil compressor from princess auto....
  20. if you take off the filler tube, you can reach behind the engine and tackle it with a ratcheting box end wrench 14mm worked well for threading the bolts aswell
  21. would i need spring compressor to fit jgc coils on my pathy?
