GoPathyGo
Everything posted by GoPathyGo
  1. All depends on price. For $500, sure why not ? For $5,000... Hmm... How many miles ? Did he wheel it ? When did the t-case bust ? Does the truck look good/bad/ugly otherwise ? That kind of info will help. R50s have dropped in value enough that, depending on where you live, you might find a better candidate nearby. As Fueler points out, it's not the end of the world but more info will help us help you.
  2. The stock air intake is the definition of restrictive. White plastic with small air holes/inlets. I used rubber radiator pipe from (I think) a Chevy HD pickup as a test piece before ordering the steel version. It matched the diameter of the hole in the air box. So it's pretty much as big as you can get without replacing the air box itself.
  3. I bought that snorkel. After a week of trying, I flung said snorkel into a dumpster. Thing is just plain awful. Instructions aren't that helpful. Stuff doesn't line up. You have to drill holes everywhere and it still won't fit. Doesn't come with all the hardware you need. It feels and is the flimsiest cheapest plastic they could find. Oh, did I mention the connection between snorkel and airbox doesn't work ? Like, literally won't fit ? Save your money. Get $100 worth of stainless radiator tube and run it behind the sheetmetal (or outside, if you like) and bring it out near the driver door. The stock airbox has a neat hole for the radiator tube to fit into.
  4. I would suggest checking the following and replacing as necessary. (Some of these have been covered above.) While the list seems long, a lot of these can be done fairly quickly visually or by touch. Some, such as the valve cover gaskets, take more time. 1. Belts 2. All hoses 3. Plugs 4. Fluid change (assuming you haven't done this very recently). Oil, tranny, t-case, diffs, brake, coolant and power steering 5. Radiator and fan (leaks, fan clutch bolt) 6. Filters (air, fuel, cabin) 7. CV boots 8. Brakes. Rotors, pads, calipers and hoses 9. Suspension. Ball joints, springs and shocks. Might want to replace these depending on when you last replaced them. 10. Electrical. Alternator and battery. 11. Valve cover gaskets 12. Cams and cylinder heads (if you're replacing 11) 13. Exhaust and heat shields. Visual inspection for leaks, tears and loose clamps and bolts 14. Sheetmetal and body. Visual inspection for rust, specially around the fenders. I'd suggest taking the flares off to see what's going on I'd also suggest running some diagnostics while she's on. See if all the measurements and readings are in line with specs. E.g., vacuum, ignition, voltages etc. This might seem like overkill. But worth doing to get the most out of the next 200k!
  5. Yeah, but the front is where I was having rub problems. The rear was never an issue. Not sure I agree the front doesn't "flex for @!*%". (That sounds like AlexRex garbage. Are you channeling him now ? ) There is a fair amount of vertical "flex"/movement. The more plastic trim, the greater the rubbing up front. Yes, the lateral flex isn't as great as a solid axle, but what is ? Besides, unless everyone else here has been wheeling backwards, there's gotta be enough for it to work.
  6. But wouldn't a 1.5" spacer get you close to the same backspacing as a 3.2" backspace wheel ?
  7. Eh, I wouldn't worry about it. People get too hung up on the lift - it's practically as bad as the "size matters" issue. I've run 35s (35.3 SSRs and they felt bigger) on the Yota and the actual ground clearance and ride height difference over 33s wasn't that great. My own highly unscientific observation is that it's a matter of diminishing returns. Stock -> AC lift yields a noticeable change. Stock tires -> 32s yields a noticeable difference. 32->33 and 33-> 35 is a "meh". I'd have to go to 37s to really notice a difference and gain big clearance advantages over the 33s I have on now. I think folks on this board have demonstrated that you can do some pretty impressive things with moderate lifts. As they say,"It's how you use it..."
  8. Castrol Fully Synthetic 5W-40. Purolator PureOne Filter. Changed based on usage. If I've been wheeling or driving in a lot of stop-and-go traffic, I'll change it at 3k miles or so. If I've just been on long trips, I let the change interval go to 4k or 5k miles.
  9. I had to basically take out all the plastic stuff at the back. The problem I ran into was that flex dropped pretty dramatically. As the pic shows, the 33s fill out the wheel wells so much that you lose some maneuverability. Of course, Alex probably has some superultrawonder thing going on that mere mortals couldn't understand.
  10. I had a custom bumper with a swing-out tire carrier. I eventually got rid of the tire carrier, but have kept the bumper. A few questions that may help as you look at options: 1. What size spare will you mount ? The larger the tire the lower the visibility out the rear. A large, heavy tire may also require you to put the tire carrier in the center to make sure the weight is evenly distributed. My 32" BFG A/Ts blocked the rear altogether. 2. How often will you carry cargo ? Mine was a pain to open, specially in urban areas, parking lots and street parking spaces. 3. How important is fuel economy and weight to you ? The bumper and tire carrier together added well over 100 lbs 4. How important are aesthetics ? A twin-tube bumper will weigh less than a boxed bumper but will not look "stock" or even "OEM-style" 5. How important is maneuverability ? Mine extended the length of the more than a foot and made parallel parking quite the adventure. 6. Cost ? My bumper, if it was done today, would run about $500-$600 - without the tire carrier. I got the tire carrier off a tube-style bumper. Mine's probably overkill though for most people - 5 bolt points each side, wraparound plate, side support brace, D-rings and stupid high clearance. Alternatively, you could just chuck the spare in the cargo area when wheeling... Good luck!
  11. has no idea what status means
    1. 1999R50
      1999R50
      Just put your marital status if comming up with an NPORA status is too hard.
  12. Low speed and some of the energy was transferred into the Prius. While I like the looks of my Nissan brush guard, 3 bolts each side torqued at 40 ft-lbs with no upper support ain't real strong... Force = Change in momentum/Duration of impact Assume a 100 lb deer, 50 mph vehicle speed and an instantaneous impact (0.2 seconds though you can be more scientific). The deer is going to be accelerated to the vehicle speed very rapidly. I simplified and assumed that was instantaneous too. I used metrics (45 kg and 22 meters/second) but converting back from Newtons to lbs it works out to about 1125 lbs. That's a lot to ask of a brush guard.
  13. GoPathyGo
    seafoam?
    Wow! Never heard of that before. Did you contact the company ? Not sure what "drain it out" means. I thought it just burns off with everything else... Also, not sure how the thinning oil and lower octane would cause detonation. I would have thought the machine would have just cut altered the mix to compensate for the lower octane... But that may just be my ignorance and lack of knowledge.
  14. I think that one's right up there with this gem... http://cgi.ebay.com/Nissan-Supercharger-Turbo-for-X-Trail-Navara-Maxima_W0QQitemZ370276739454QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item563636a97e
  15. Would the lightforce nuts work ? I'm getting them for the Blitzes and HID mounted on the truck. http://www.lightforce.com/products/accessories/security-nuts
  16. Has you friend tried All Pro Offroad, ICON Vehicle Development, Toytec Lifts and some others ? All these guys (and others) make some form of long-travel kit for the Tacoma and FJ Cruiser...
  17. Brandywine has amongst the worst prices around. One guy offered me a door for MORE than a new one from the stealership. Try Crazy Ray's in Jessup. R50s show up there regularly, though no guarantees on the wheels. Condition varies but only once have I seen R50s that were so trashed that basically nothing was salvageable... Well, maybe the cigarette lighter.
  18. GoPathyGo
    CV AXLE
    3" SL + 33s + Engaged in a bad winter could do it...
  19. The jack points should look like little upside-down saucers on the frame rails. I usually put the head of the jack as close to the center of the saucer as I can.
  20. Yeah, I got 'em to fit. TrXus 255/85-16s that came in at 32.8" BUT that was after basically removing the fender flares, removing pretty much all the plastic in the wheelhouse (few pieces left), 3.125" backspacing and new struts (hadn't sagged). The problem was that the tires took up so much room they whacked the rest of the body pretty much any time the suspension seriously flexed. The 1.2" over the BFGs didn't sound like much when I ordered them, but the increased tire size and the very aggressive lugs made a real difference. I ran into the same problem when I tried 35s on the Yota. Even with low backspacing the 35s were hitting the frame and killing flex. Went back to the 33s. Basically, I think you practically need an SFD/SAS to really use 33 and up to their full potential... Not saying it can't be done. Just that there are limits and the noise/bashing can get pretty annoying.
  21. Boy I hope they don't have speed bumps where those guys live...
