Everything posted by Casey.T
If the previous owner does not know if it was done... And you got the records for the servicing of the Pathy and are not finding a reciept.... Assume it has not been changed.... 95's should have the 105k belt(Rounded Teeth) I would suggest getting both the Haynes and Chiltons Manuals. Someone here should have the FSM on a PDF file. It is not extremly complicated to change, between Chiltons and Haynes its pretty much covered. Time, patients and maybe a call or two to 1.888.69S.LICK Total time on changing the my T-Belt, minus the waiting till the next day to get the correct (Rounded Teeth) about 3 hours. While your in there, change the water pump and T-Stat...
MuD TiMe Then Pic's
R50 Hidden Winch Mount recovery system
Casey.T replied to Runnerman's topic in 96-2004 R50 Pathfinders
:bow: -bounce- :bow: -
Welcome 101k, You might want to talk to a Nissan Dealer about possibly fixing the broken Studs for free.... Nice and Clean... Kinda looks like WheelmanLS
93.... Deal....
We will go find you a good one when you come back.... You go Tuna Fishing yet????
ReviewBlack Panther Skid -bounce- Cant find my linky.
Having the front end in the air will make it easier to remove and to crank them down..... After adjusting them you will have to move the Pathy to see where your final adjustments landed you on height and if your level.... may take a couple of tries to get it perfect..... Or when you take it in for the alignment have them level it out.....
The Kit sitting on the Tow Strap and the Lego wheel caps is the kit that the Spark plug tool comes in, with the tire iron.
Rust.....
Not sure what the wifey has planned for that weekend... As it stands now I am thinking we will be in town most of if. I got to get an engine out, then the new one in and up and running prior to June 10.... If we are not in town we will head up to the Colville Area, got phone ###s if needed to arrange a meet. Mettaline has lots of logging trails... If you have a Gazzatter, most are plainly marked, and dont require 4wd. Lots of lakes bring your fishing rods. -bounce-
Loosen up the 3 bolts on the front a little, then do some tapping on the bars.... they should almost fall out.... If your putting these ones back in, make sure you mark them Left and Right... Also mark them for indexing to get them back in almost the same spots....
I think I am about ready to give up on my 95 SE
Casey.T replied to zack1978's topic in 90-95 WD21 Pathfinders
Lets see some Pics...... -
EGR Port is on the Drivers Side... just to clarify
VAROOOOOOOOOOOmmmmmmmm!!!!!!!
Welcome Search will be your friend -bounce-
Wheel, I cried.... Now if you were alittle closer we could talk Doors and Wheels... I am glad that your are no worse for ware **Pays Hommage to the Black XE
Someone please pass Rami some Beno'
DJD also has a little something in the back of his.... I remember commenting on it and all the straw he had in the back....
Lmao... Stayed home all weekend and did nothing This week end is Saturday Afternoon Flyfishing on Bailey Lake north of Chewelah.
Rami, Ill check out the all of links when I get to the home comp, but that area looks like prime Elk Hunting???? I do miss that side of the hill.....
Looks like Rami had some fun -bounce- I am not understanding the facinaition of taking of picture of the Rigs "Peeing" on the side of the road.... Everyone does it its natural -bounce- Crown Royal Write up?????? I really hope to screw up step 1 and have to contiually redo till I get it right....
JWT Got the right one this time...
The Distributor cap was loose... you could turn/twist left and right by hand???? That could be the problem... the compter controls the ignition advance, and if the cap was loose it could drastically effect the Timing/running of the engine.
