Hello all
I have a 95SE with 130k on it. I acquired it last summer(6k) after litterally driving my 88SE into the ground as I swore I would (260k and now the brother-inlaw's mother is driving it) Long Story. Then when I was bragging about my new 95 my manager says, I have a 92, $2500 later I have 3 Pathfinders -alcohol-
I have never really been a grease monkey or a more mud the better type of 4x4'r.
And what ever I do to the 95, I will eventually do to the 92.
I have not decided if the Daughter will be driving the 92 or if it will become the Hunting Machine.
The List:
Broken Exhaust Header bolts Passenger side, had 2 left. Due to time constraints and availablity had to use a junk yard replacement on the warpage.
Pacesetter has replacements and I will be getting a set. Need a Good link on where I can buy a set of ceramic coated ones, due to the heat that they are noted for any little bit of heat reduction will help.
BTW I can license these in a non inspection county if needed, sssh if someone has a better Idea.
Mass Air Flow??? (Engine seem so starve for more air when its hot out) Only one I have found so far for a after market is Venom. Suggetions.
Intake systems, got the KN Filter already. Those intake Inserts??? Turbonator.com LOL
Ignitions systems?? Better than stock?? MSD?
Converting from the Clutch Fan to a Elictirc Fan System, reduce engine drag and increase air flow. (The 92 will eventually be doing some puddle jumping)
Good/Bad Ideas
Skid Plate: Black Panther has a great one imo, only challenge is the amount of snow we get and if its to much the front end will lift. Did that with the 88 and the plate I had made.
Replacement Shrouds for engine compartment.
Trouble shooting:
Factor Fogs, do not work, Switch on console behind e-brake
Suspension Toggle Switch, What is this for? fixing/repairing???
Left front turnsignal: Cracked by previous owner was rusted out, swapped it with the 88 worked for 2 days now nothing. Signal on dash flashes really fast.
Left rear brake light, swapped bulbs worked for about 3 min or until driven for 3 min. Now if i just reset the bulb it works until you put it back in the holder and go down the road. (Annoying)
Condensation Drips on passengers foot occasionally, 88, 92 and 95, I never sit over there so it does not bother me
For me I just want to get a bit more out of it, and have what we need for those occasions when the directions do include after you leave the paved road.
Thanks
Thomas
