M in KC
Everything posted by M in KC
  1. More than likely it's a broken exhaust stud and the exhaust manifold has warped. Pretty common problem for pathys. Header install isn't to big a deal but removing any and all broken exhaust studs can be a MAJOR PITA. The water jackets are extremely close to the stud holes and much of any deviation in drilling to remove them is where the real fun usually starts. Pacesetter and Thorley make after market headers for pathys mated to a Flowmaster 40 or 50 series muffler will give you a little "throat" to your exhuast sound. Your factory emissions junk should work with either header manufacturer. JMO Mike
  2. Now that's a bumper! Dang!
  3. Judas Priest nice action photos guys! I'd say there's a couple of us out there that can turn a tire in the bush.
  4. What about epoxy appliance paint? You might be limited in color though, I'm not sure if BMW made an avacado green or not. I used the gloss black on the restoration of my 750 kaw triple. The big box home improvement stores should carry it. JMTC Mike
  5. Wow, did you see this on feebay! Item no. 4561485016. '92 XE opening price $6.00 and no reserve. Man is this the spirit of free enterprise and allowing the market to drive the price of goods or what? This is obviously an experienced seller not a first time green horn. I wish them well. You guys in Cali might take a look.
  6. 5-30 M1 since day one. No smoke no leaks. I clicked 149K on my '91 over the weekend.
  7. Thanks for all the insite. I knew you could buy belts in incremental length differences. I was just hoping someone already had some other possible belt numbers. So I guess when this one starts to squeel I'll be starting a little R&D project for either a shorter belt or an alternator bracket shrinker. Mike
  8. I changed the v-belts on my 'finder ('91 V6) over the holiday. Is it just me or is replacement alt. belt too long. The parts house matched up the same belt number that I had on there. I swear I'm at the end of the tensioner's limit after I installed it. And no I didn't over tighten it it has about 3/4-1" of deflection on the longest run between pullies. It's not slipping but I haven't put enough miles on it to break it in yet either. Just wondering. Mike
  9. Way black with sooth, oil, other???
  10. Holy Freakin' cow. :cool2: No kidding a tool in the tire changing bag! Man I'm just like everyone else you have to stand on your head and spit out silver dollars, braek you hnd in three places to change that plug. I'll have to check tool bag. I have crafted a sparkplug removal tool vai some extesions a wobble joint and some duct tape. Not pretty but its effective. Run platnium plugs and your good for a looooooooong time between changes. Mike
  11. Been there done this one as well. I'm on my third starter. OEM worked for 12 years. First aftermarket worked for 1 month. Second aftermarker still working. You might have suspect repacement starter. My second aftermarket starter has not exhibited these symptoms (knock on wood). I have felt your pain. You might also check the little rubber-booted electrical connection at the starter (my '91s is red or orangeish colored). If that's loose it might ellicit the same symptoms. Good luck to ya. Mike
  12. Dang, I feel like a dumbarse. Thanks Pezzy.
  13. O.K I give up where is the new discussion by model year forum? Sorry for being technilogically challenged. I some times have a hard time with a rubber band and a peanut shell. LOL. Mike
  14. You Da' Man 88! Thanks for all your efforts! Mike
  15. I did the MAF sensor cleaning thing this weekend. For those of you have done theirs, did you see much gunk on yours? Mine looked whistle clean except for some grey deposits on the posts holding the wires. Just curious. I'll fill 'er up and see if I made any improvements. Mike
  16. Jason, my MPG numbers were almost identical to APC's after my repair. My stealer's tech described it to me this way. With the exhaust leak ahead of the O2 sensor you are drawing in more fresh air at the leak(s) and there by artifically leaning out the exhaust gas that the O2 sensor is detecting. The O2 sensor in turn is telling the motor it needs more fuel and ta da! your MPG goes in the crapper. I'm no techno genius but the theory seems to hold water. Others that are more savy regarding engine management systems on these rigs will fill in the blanks that I left out. Oh and $125 clams for stud removal is not to shabby. Next, I'm going to try 88's MAF sensor trick to see if I can squeeze a couple of more MPG's out of my rig. Happy Camping! Mike
  17. Thinking more last night, something that I would also consider doing prior to installing your headers is wrapping them with high heat tape. Somebody makes a header insulating tape. The high temp paint that came on the headers from Pacesetter will last about 30 seconds once the pipes are heated up. And if you think the 1200 degree rattlecan paint is any better, it isn't. By wrapping the headers prior to installation you will keep the temps in the exhaust gases in the headers as high as possible which will improve performance. Meaning the exhaust gases will flow faster and easier if they are hotter thereby letting the motor breath more freely. And the starter and other things will be kept cooler because of the insulation as well. JMO Mike
  18. Call Pacesetter and confirm you have the right header set for your application (e.g. year, A/T, M/T). They will fax install instructions if you didn't get them with your kit. Don't ask me how I know this. The bunges on the driver side header are more than likely for the EGR circuit. At least one should be. I'm sorry I can't be more definate since I have a '91 V6. Another thing to stongly consider is to "round file" the exhaust manifold gaskets that came with the kit and up grade to some Fel-Pro gray graphite colored ones. Stock O2 sensor should work with the header set fine. Mike
  19. Slick, did you see any mpg gains or losses with your headers? You're probably making more hp but dropped some torque with your header-flow master combo. Correct? My Pacesetter-flowmaster combo made a noticable change in hp and a drop in torque. My milage did pick back up to 19-20 from 17-18 range. Granted tires, driving habits and a multitude of other things play into fuel economy. I'm just curious on the performance differences between the header manufacturers all else being equal. Thanks Mike
  20. Next time you recharge the system put some dye in the refrig oil. This is the acid test for a fugitive freon leak(s). The stuff I used last was a chartrouse color. sly Mike
  21. Darn, 88 is gooooooooooooooooooooooooood!
  22. Broken exhaust studs in these engines are a _ _ _ _ _. It can be done. I did one on mine when I did the header install. Soak the stud as best you can with the penetrating oil of your choice. Kroil, PB Blaster and Deep Creep are good choices. I'm sure others wil chime in with their favorite weapon of choice. Anyway as the Precise1 said the start is mission critical. If you slide the drill bit off the stud and into the water jacket you are toast. Start with a good center punch and cup out the stud if you can with a rotary tool (e.g. dremel etc.) From there it's slow and steady that gets the prize. Depending upon which stud is broke off this may be a two person job. My bro and I had to do mine. One below with variable speed right angle drill and a titanium left twist bit and one person on top holding the drill head and a small spotting mirror. Slow, slow, slow. Once you get a pilot hole started stop before you go too deep. Measure and mark your drill bit a lenght short of what is left of your stud. Don't drill to China! From there it's a screw extractor if the drill bit hasn't backed the stud out. I would suggest a handfull of drill bits you'll probably break a few. Good luck if you decide to do it. Mike
  23. I would think so. Although they're liable to give you the standard disclaimer. The hi-temp copper is good stuff as well but you'll still have to split the joint. Head for the sawsall and either a gasket from the parts house or a tube of copper and some nuts, bolts and washers. Wear some eye protection if you choose to do it. There is going to be a lot of junk falling while your working on it. Eyes the pair without a spare. Mike
