headpeace last won the day on November 11 2010
headpeace had the most liked content!
93 SE, 215k + miles, 3" BL, RC UCA's, t-bars cranked, rear sway gone, 33x10.5x15 BFG AT KO's, IAB, K&N filter, pro comp 9000 shocks, Thule roof rack for my canoe, thats about it I think, well new stereo of course Little Rock, Arkansas
36-40
1993
Contact Methods
Website URL
http://
ICQ
Gender
Little Rock, AR
Country
8,161 profile views
headpeace's Achievements
NPORA Old-Timer (5/5)
17
headpeace started following Where is the fuel pressure regulator on a '93?
headpeace replied to Flysilly's topic in 90-95 WD21 Pathfinders
Would a faulty fuel pressure regulator cause hard starting? But then run fine once started? -
starter question,UPDATE WITH PICS !
headpeace replied to ahardb0dy's topic in 90-95 WD21 Pathfinders
If while running I show 14.3-14.4 volts can I assume the alternator is properly charging the battery? -
After I jumped the wires my battery was dead the next morning. Now I remove the jumper when not in use until I can find a cheap hazard light switch - No more dead battery. Jumping the wires must cause a slow drain on the battery when not in use.
crickets...
For you all that have snorkels, how did you attach the snorkel to the A pillar by the door?
EGR Function Check Engine Light problem.....? RESOLVED!
headpeace replied to leeuniverse's topic in The Garage
That did it, flat head screwdriver at top middle of plate and a whack with the hammer. I was afraid I was going to tear up the gasket but it came out ok. That thing was caked full of build-up, got it all cleaned out and EGR seems to be functioning correctly also. Unfortunately my pathy is still running like @!*%, let the troubleshooting continue... -
How do you get the EGR Diverter off? I got the bolts out and tried to pry it off with a flat head screwdriver but it is like baked on I guess, it wouldn't budge. -
Yep, I agree. The new hazard switches I found were all around $40, jumping the wires was free. Hopefully this will help some one else eventually.
Well I finally fixed the dam turn signals. I'll share my solution: first make sure it's not the flasher that is bad. I bought a new one, took it home and installed it - didn't fix the problem so I took it back and got a refund. The connector that plugs into the hazard light switch has numerous wires coming into it, jump the red striped with yellow wire to the brown striped with white wire - that fixed mine, now I have turn signals again.
Me too. Door lock timer behind rear driver side panel in back.
How do you get the connector unplugged for the sensor going to the ECM?
The hazard switch appears to be just as it should be. Rocks back and forth smoothly and performs its job as intended. I added a ground to the current setup at the flasher plug harness and that did nothing but blew the hazard light fuse when I turned the hazards on. I put a new flasher in and I didn't get the buzzing noise but the turn signals still do not light up appropriately. Does the hazard fuse blowing after adding a ground to the black wire connection in the harness indicate proper performance or not?
Can any of you all that know how to look at the electrical diagrams tell me which wire going to that flasher is the ground?
So I found this link. After searching under the steering wheel I located the flasher, I confirmed that this is where the buzzing noise is coming from. So the fix here sounds promising, does anyone have a pic on how the flasher is removed? I cannot see how it is attached due to the way it is installed.
Could this possibly be a faulty headlight/turn signal switch?
