navygz19 Posted October 18, 2006 Share Posted October 18, 2006 Bought a little Radio Shack CB today (had the same one years ago in my HB and it got the job done ) and I'm going to put it in the slot towards the bottom of the console, and cut out the two plastic pseudo-buttons for where the heated seat buttons would otherwise be. What's a good hot wire to use back inside the console? Should I just go ahead and remove the entire thing? If so, where's the screws? Sorry, never pulled this one apart before, appreciate the help! -Gianni Link to comment Share on other sites More sharing options...
vengeful Posted October 18, 2006 Share Posted October 18, 2006 If you want it constant-hot, you'll have to run a lead from the battery. There are two screws at the bottom of the cover panel, and two at the top behind the HVAC Vents which will have to be pulled out in order to access them. If you're not looking for a constant-hot, the cig. lighter is a good spot to tap into. Link to comment Share on other sites More sharing options...
navygz19 Posted October 18, 2006 Author Share Posted October 18, 2006 Yeah I'll end up doing the cig. lighter. Do I have to tap into it at the fuse box? Link to comment Share on other sites More sharing options...
nige Posted October 18, 2006 Share Posted October 18, 2006 I spliced mine in a few inches before the lead goes into the back of the plug. Beware, you might get some interference from the ignition. Link to comment Share on other sites More sharing options...
RWC5S2 Posted October 18, 2006 Share Posted October 18, 2006 I mounted my CB on the right side of the center console and about even with the @!*% lever. If the CB is a smaller style it does not interfere with the passenger at all and is only a few inches from the cig lighter. Makes it easy to get to also. Link to comment Share on other sites More sharing options...
navygz19 Posted October 18, 2006 Author Share Posted October 18, 2006 I spliced mine in a few inches before the lead goes into the back of the plug. Beware, you might get some interference from the ignition. You mean like a "whining" noise, as speed increases, etc.?(sort of reminiscent of poor AM radio reception) Why would splicing at the cig. lighter allow that to happen? Link to comment Share on other sites More sharing options...
Pathfinder_Rookie Posted October 19, 2006 Share Posted October 19, 2006 Ya a CB a Handy thing to have. I had that noise too, but i just moved my ground wire to one of the bolt that hold the 4x4 boot on. I had a larger Cobra which i had in that CD Pocket, but it burnt itself out. My new one, i installed on the button bar. Take a Look. Link to comment Share on other sites More sharing options...
navygz19 Posted October 19, 2006 Author Share Posted October 19, 2006 Wow that looks great. Nicely done Link to comment Share on other sites More sharing options...
Pezzy Posted October 19, 2006 Share Posted October 19, 2006 Looks good Path-Rookie... mine is installed in that same spot! Link to comment Share on other sites More sharing options...
Trainman Posted October 19, 2006 Share Posted October 19, 2006 Of course, if you had the AllMode system, you could do it this way: Link to comment Share on other sites More sharing options...
navygz19 Posted October 19, 2006 Author Share Posted October 19, 2006 I'm looking for the two lower nuts to remove in order to get the plastic bezel off the dash. I've got a slightly different setup than yours Pezzy as well as yours, Veng. I think the first nut I have to remove is underneath the ashtray, and then go from there? I'm putting mine exactly where yours is, Pezzy Ahh yes, AllMode, I wish Link to comment Share on other sites More sharing options...
NismoSkyZ Posted October 19, 2006 Share Posted October 19, 2006 There are two phillips head screws on the underside of what i circled. Just take those out and wiggle the plastic face off. At least thats how it works with the 96-99. Link to comment Share on other sites More sharing options...
Pezzy Posted October 19, 2006 Share Posted October 19, 2006 I think the first nut I have to remove is underneath the ashtray, and then go from there? Where is your ashtray?? Link to comment Share on other sites More sharing options...
vengeful Posted October 19, 2006 Share Posted October 19, 2006 You don't have to do anything with the ashtray! http://www.fnd4pth.com/R50/FSM/2004/bt.pdf <-- Right Click, Save As That's for a 2004, but it'll be the same for you. There's a diagram on BT-26. There are two metal clips at the bottom edge where are circled above. There are two screws behind the HVAC Vents above that center panel with the clock in it. That assembly is only held in by a metal clip. Just pull, hard. You won't break it. Link to comment Share on other sites More sharing options...
vengeful Posted October 19, 2006 Share Posted October 19, 2006 Link to comment Share on other sites More sharing options...
navygz19 Posted October 19, 2006 Author Share Posted October 19, 2006 Ok HERE'S the center dash... Here's the underside of the center dash. Note there are no screws underneath it. Here's where my ashtray is located. And with the ashtray removed, here is the center console screw underneath it. And ideas? :confused: Link to comment Share on other sites More sharing options...
vengeful Posted October 19, 2006 Share Posted October 19, 2006 See my posts above....:idea: Link to comment Share on other sites More sharing options...
navygz19 Posted October 19, 2006 Author Share Posted October 19, 2006 Ok that helps, thanks a lot! I was too hell-bent on looking for screws on the bottom of the dash, as is the case in pre-00's. Link to comment Share on other sites More sharing options...
navygz19 Posted October 19, 2006 Author Share Posted October 19, 2006 See my posts above....:idea: Yeah, stupid a$$ slow connection Link to comment Share on other sites More sharing options...
navygz19 Posted October 19, 2006 Author Share Posted October 19, 2006 Thanks a lot, man Link to comment Share on other sites More sharing options...
vengeful Posted October 19, 2006 Share Posted October 19, 2006 No problem. I knew there was a reason I put the unizipped 2004 FSM on my server...:idea: Link to comment Share on other sites More sharing options...
navygz19 Posted October 25, 2006 Author Share Posted October 25, 2006 I got it in today...it fits perfectly! Thanks for the help, guys (and girls) Link to comment Share on other sites More sharing options...
navygz19 Posted October 25, 2006 Author Share Posted October 25, 2006 Sheesh, that sounds like something it's not suppossed to be! Link to comment Share on other sites More sharing options...
Jarsiff Posted October 29, 2006 Share Posted October 29, 2006 I was just thinking a cb would be a smart idea to have and bam you guys have a post on it, hehe, those pocket installs cutting out where the h.s. switches would be are really clean! :cool2: i like it alot and will be copying you Link to comment Share on other sites More sharing options...
