Jbaird313 Posted October 6, 2018 Share Posted October 6, 2018 (edited) Wanna make clearance with 33’s hoping I won’t have to do any metal body trimming. Is that possible? Still using 15inch rims/wheels. Current tire size is 265/70/R15 uses a 2.5inch strut spacer to lift it. Edited October 6, 2018 by Jbaird313 1 Link to comment Share on other sites More sharing options...
Smallpathy Posted October 6, 2018 Share Posted October 6, 2018 You should be able to but you will definitely need to run spacers to clear the strut tower and frame. I have been getting ready to do the same thing. Wanna make clearance with 33’s hoping I won’t have to do any metal body trimming. Is that possible? Still using 15inch rims/wheels. Current tire size is 265/70/R15 uses a 2.5inch strut spacer to lift it.Sent from my Pixel using Tapatalk Link to comment Share on other sites More sharing options...
Jbaird313 Posted October 6, 2018 Author Share Posted October 6, 2018 34 minutes ago, Smallpathy said: You should be able to but you will definitely need to run spacers to clear the strut tower and frame. I have been getting ready to do the same thing. Sent from my Pixel using Tapatalk Are you worried about any issues the wheel spacers may cause Link to comment Share on other sites More sharing options...
Smallpathy Posted October 6, 2018 Share Posted October 6, 2018 I run 2.5 inch spacers on mine just make sure they are good quality, follow directions, and check them to make sure they are tight when you change your oil and other routine maintenance. Are you worried about any issues the wheel spacers may cause Sent from my Pixel using Tapatalk Link to comment Share on other sites More sharing options...
Smallpathy Posted October 6, 2018 Share Posted October 6, 2018 Or get wheels with decent back spacing/offset if you don't want to run spacers. Are you worried about any issues the wheel spacers may cause Sent from my Pixel using Tapatalk 3 Link to comment Share on other sites More sharing options...
Jbaird313 Posted October 6, 2018 Author Share Posted October 6, 2018 I appreciate the information man, will definitely look into. Link to comment Share on other sites More sharing options...
Smallpathy Posted October 6, 2018 Share Posted October 6, 2018 I appreciate the information man, will definitely look into.Ya npSent from my Pixel using Tapatalk Link to comment Share on other sites More sharing options...
mjotrainbrain Posted October 6, 2018 Share Posted October 6, 2018 For about $50 a piece (so cheaper than the average quality wheel spacers) you could get 15" wheels of the proper specs. I had great luck with ProComp PCW51-5883. To run 33's, you're going to have to do some serious trimming. A handful of people have done it on 2" lifts, and it really does require butchering the body panels. 2 Link to comment Share on other sites More sharing options...
KiwiTerrano Posted October 6, 2018 Share Posted October 6, 2018 If you run a skinny 33, ie a 10.5 not 12.5 section, or a 255/85r16 they'll fit better than a 12.5 or a 285/75r16 3 Link to comment Share on other sites More sharing options...
Jbaird313 Posted October 6, 2018 Author Share Posted October 6, 2018 7 hours ago, mjotrainbrain said: For about $50 a piece (so cheaper than the average quality wheel spacers) you could get 15" wheels of the proper specs. I had great luck with ProComp PCW51-5883. To run 33's, you're going to have to do some serious trimming. A handful of people have done it on 2" lifts, and it really does require butchering the body panels. You think I’ll have to trim the metal body at all ? Or just the plastic going under neath the wheel wells, I planned on removing fender flares as well and mud flaps. Link to comment Share on other sites More sharing options...
system_f Posted October 6, 2018 Share Posted October 6, 2018 275 75 16s fit on stock wheels with high-quality hub centered 1" wheel spacers with little issue. These tires are a tad bigger than 32" tires and only required a small inside front bumper trim and removing front mudflaps 2 Link to comment Share on other sites More sharing options...
Jbaird313 Posted October 6, 2018 Author Share Posted October 6, 2018 51 minutes ago, system_f said: 275 75 16s fit on stock wheels with high-quality hub centered 1" wheel spacers with little issue. These tires are a tad bigger than 32" tires and only required a small inside front bumper trim and removing front mudflaps Are those available in 15’s ? Cause that’s what I’m currently running Link to comment Share on other sites More sharing options...
Zraver Posted October 22, 2018 Share Posted October 22, 2018 I had to trim the plastic flairs back and roll the lower portion of the fender near the convergence of the bottom and the door. It aint pretty, but it works. Link to comment Share on other sites More sharing options...
Bax03SE Posted November 23, 2018 Share Posted November 23, 2018 First off, haven’t been on here in a looong time. I picked up a C4 corvette this past summer and that has turned into the project that sucks all my time lately. Still have the R50 though. I’m running 285/75/16 mud terrains which works out to about 33x11.5 with approximately 2.5 to 3 inches of lift. There is just no way you will get 33 or larger tires on that size of lift without cutting into the metal. Personally, I took a lot of time with the trimming on mine so I feel it looks pretty clean and would not be noticeable by anyone unless you have another R50 to compare it to, but it definitely took a lot more trimming than I originally expected. I was also unwilling to accept any rub at all at full lock, so I probably cut a bit more than some who are okay with just “good enough”. That said, if your not shy about cutting I think it’s well worth it. I love the final result of the 33’s with a relatively small amount of lift. 4 Link to comment Share on other sites More sharing options...
Cbiggy Posted April 15, 2019 Share Posted April 15, 2019 On 11/22/2018 at 7:31 PM, Bax03SE said: First off, haven’t been on here in a looong time. I picked up a C4 corvette this past summer and that has turned into the project that sucks all my time lately. Still have the R50 though. I’m running 285/75/16 mud terrains which works out to about 33x11.5 with approximately 2.5 to 3 inches of lift. There is just no way you will get 33 or larger tires on that size of lift without cutting into the metal. Personally, I took a lot of time with the trimming on mine so I feel it looks pretty clean and would not be noticeable by anyone unless you have another R50 to compare it to, but it definitely took a lot more trimming than I originally expected. I was also unwilling to accept any rub at all at full lock, so I probably cut a bit more than some who are okay with just “good enough”. That said, if your not shy about cutting I think it’s well worth it. I love the final result of the 33’s with a relatively small amount of lift. would you mind posting pictures of what you've cut? 1 Link to comment Share on other sites More sharing options...
