Jbaird313
Everything posted by Jbaird313
  1. Sadly don’t have before pictures I seem to have lost them. But if anyone is trying to find out what a 2.5 inch strut lift will look like on their pathy, I hope this helps. Also to note if you do use 2.5 inch strut spacers, you’re going to have to use camber bolts. Something I haven’t don’t yet but will get around to. Hope this helps!
  2. Thanks for explaining in more detail. Will I experience any issues, I only plan on staying on the highway for now. Until I get my new tires and wheels. Then I was gonna have it re-aligned. Should I wait till I get it re-aligned again? Or put the camber bolts on ASAP?
  3. Are those available in 15’s ? Cause that’s what I’m currently running
  4. You think I’ll have to trim the metal body at all ? Or just the plastic going under neath the wheel wells, I planned on removing fender flares as well and mud flaps.
  5. I appreciate the information man, will definitely look into.
  6. Are you worried about any issues the wheel spacers may cause
  7. Wanna make clearance with 33’s hoping I won’t have to do any metal body trimming. Is that possible? Still using 15inch rims/wheels. Current tire size is 265/70/R15 uses a 2.5inch strut spacer to lift it.
  8. Thanks, the colors my favorite too. Only has 109k on speedometer and I just replaced the entire suspension
  9. I have a 2.5inch spacer on my 94 and my cambers off just a pinch now and the tires bow in. Worst comes to worse tho you can just get some camber bolts and have it fixed.
  10. Thanks for all the help guys! Will make sure to get these camber bolts and work on it with my mechanic.
  11. Is this an easy enough job that I can get my mechanic to do it? Or will I have to goto an alignment place to get it done. And after it’s done will I have to get it realigned again? Thanks for the quick response btw
  12. Lifted my 96 pathfinder with some 2.5inch strut spacers and got all new struts and front axel. Issue is got it aligned thinking it would fix my camber issue as well but they told me they couldn’t adjust it. Tires are cambered in and just need help on what to do next. And will I experience any issues down the road? They’re barely noticeable.
