John Boy Posted June 10, 2006 Share Posted June 10, 2006 So I finally got my factory fog lights working and was dissapointed to see that they only work with the headlights on. So is there a way to get them to work without the headlights on :confused: Link to comment Share on other sites More sharing options...
94extreme Posted June 10, 2006 Share Posted June 10, 2006 look around the forums (search) and you'll find a few different mods. good luck Link to comment Share on other sites More sharing options...
GrimGreg Posted June 11, 2006 Share Posted June 11, 2006 Most have a switch wire running off the headlight wires, just run that to a hot lead. Link to comment Share on other sites More sharing options...
El Pathfindero Posted June 12, 2006 Share Posted June 12, 2006 I've got a foglight ? too: when I bought my pathy the passenger side light was missing and the driver's was broken so i tore them out and bought a pait of $40 dollar superwhite ones to go in the place, but can get no light out of them with our without headlights on Where's the fuse for these friggin things? (93) Link to comment Share on other sites More sharing options...
GrimGreg Posted June 12, 2006 Share Posted June 12, 2006 The fuse is in a little weather proof fuse holder on the passenger side wheel well under the hood. Link to comment Share on other sites More sharing options...
ILoveMyPatty Posted June 13, 2006 Share Posted June 13, 2006 I've got a foglight ? too:when I bought my pathy the passenger side light was missing and the driver's was broken so i tore them out and bought a pait of $40 dollar superwhite ones to go in the place, but can get no light out of them with our without headlights on Where's the fuse for these friggin things? (93) Just run a wire from your fuse panel to a toggle in the dash, from the toggle acc to the lights, then ground the lights on the bumper? Link to comment Share on other sites More sharing options...
El Pathfindero Posted June 13, 2006 Share Posted June 13, 2006 Just run a wire from your fuse panel to a toggle in the dash, from the toggle acc to the lights, then ground the lights on the bumper? I've already got wires running to my rrof for my forward-facing lightbar, wires going to the rear facing light bar and wires going to the spot's in my grillegraurd I'd like to recycle the stock wiring if possible The fuse is in a little weather proof fuse holder on the passenger side wheel well under the hood. Whats it labeled as?? theres like 6 of 'em Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 13, 2006 Share Posted June 13, 2006 Look for a relay on the firewall on the passenger's side, near the hood hinge. (It might be placed somewhere else, but it's the only Bosch relay by itself in there) Follow the wiring and you will have the correct fuse. Link to comment Share on other sites More sharing options...
El Pathfindero Posted July 15, 2006 Share Posted July 15, 2006 Figured it out...traced the power wire back into my steering wheel of all places and found that it had been cut off (probably to keep fuses from blowing) rewired it into my acc. and now they work great sly Link to comment Share on other sites More sharing options...
94extreme Posted July 15, 2006 Share Posted July 15, 2006 don't forget to wire in a relay in there or you're gonna have a meltdown. Link to comment Share on other sites More sharing options...
