Another 2 door on ebay
jj big shoe
yea i was kinda wondering the same thing, i have never heard of a 4 inch body lift. But eh, maybe it is ok, who knows, i just have never liked just body lifted vehicles, put suspension on if your gonna wheel your rig....
That scares me...where do you think they got a 4" body lift?
...that's right, somebody made it themselves. Probably cranked SAE bolts into the metric threads and called it good. Scary.
4" metal body lift
Yeah, that metal part is questionable. Did they just make 2" round tube spacers, if so do they have anything to keep them centered? Or, did they weld the body to the frame?
I asked about the lift. Here is his answer:
they are 4x4inch square tubes (verry thick) turned sideways and a hole drilled through ... stock rubber mounts still on vehicle and not welded to frame.
From the sounds of it, the blocks could turn, unless he has two bolts through them.
