Guest 95path addict Posted March 8, 2006 Share Posted March 8, 2006 Hi, new to the forum but not new to pathfinders but i have a question about power steering feel . This is the first 91 pathfinder i have owned and it is less responsive and harder to turn than my 95, is this normal for 91 models Link to comment Share on other sites More sharing options...
Trainman Posted March 8, 2006 Share Posted March 8, 2006 Welcome! I have an '02, so can not help much but someone will be along who can. Link to comment Share on other sites More sharing options...
SC88Pathy Posted March 8, 2006 Share Posted March 8, 2006 Welcome! As far as I know there shouldn't be any major differences between a 91 and a 95 as far as stock steering feel is concerned. Couple of questions: different size tires between the two? Proper level of power steering fluid? Power steering pump functioning properly? It could be that the center link is worn in the 91. The center link is a serious weak point on the pathfinder. The idler arm could also be bent if you'v been doing any offroading with the 91. How bad was the storm damage where you are in LA? It's still really bad down there in some areas from what I'v seen and heard. Hope we can help you with any other questions you might have! Link to comment Share on other sites More sharing options...
Guest 95path addict Posted March 8, 2006 Share Posted March 8, 2006 Hope im posting in the right spot , anyway thanks for the super quick response and thanks for asking about storm but im about 60 miles south of New Orleans it did get fairily bad but no flooding or serious damage here in Houma anyway Link to comment Share on other sites More sharing options...
Slick Posted March 8, 2006 Share Posted March 8, 2006 hello and welcome. my steering is "firm"... and i have changed my idler arm and my CL looks good.... like said above.. any dofference in set up/tire sizes? Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 8, 2006 Share Posted March 8, 2006 If the 95 had 235/75/15's and your 91 has 31x10.50x15's, it'd make a bit of difference in turning effort. Then again, it may be something else entirely. Link to comment Share on other sites More sharing options...
dagwoodzz Posted March 8, 2006 Share Posted March 8, 2006 -bounce- -bounce- -bounce- Welcome Aboard! My wife is from Houma! Me and the Pathy are over there at least every other month. Do you go off-road much? Add your mug to the map so Louisiana won't look so empty. http://www.frappr.com/npora Link to comment Share on other sites More sharing options...
94extreme Posted March 8, 2006 Share Posted March 8, 2006 welcome. sound like everyone got you covered. Link to comment Share on other sites More sharing options...
RedPath88 Posted March 12, 2006 Share Posted March 12, 2006 Welcome to the boards Link to comment Share on other sites More sharing options...
fordsho90 Posted March 14, 2006 Share Posted March 14, 2006 welcome late as usual Link to comment Share on other sites More sharing options...
