Maz Posted February 8, 2006 Share Posted February 8, 2006 Well my trailmaster lift kit has finally arrived after 3 months of waiting now I have to pay for it . WIth this kit I can still crank up the torsions a little and put taller springs in. This is the way this kit looks to me. Anyone have any info they wanna pass on? Link to comment Share on other sites More sharing options...
SC88Pathy Posted February 8, 2006 Share Posted February 8, 2006 Supposedly you can. However no active user has done this (apparenlty a now inactive member did it once). Link to comment Share on other sites More sharing options...
wheel366 Posted February 8, 2006 Share Posted February 8, 2006 PICS PICS PICS Link to comment Share on other sites More sharing options...
Slick Posted February 8, 2006 Share Posted February 8, 2006 *will exchange useless advice for pics* Link to comment Share on other sites More sharing options...
headpeace Posted February 9, 2006 Share Posted February 9, 2006 did it come with coils and/or UCA's? Link to comment Share on other sites More sharing options...
FLApathy Posted February 9, 2006 Share Posted February 9, 2006 the TM lift comes with coil spacers and UCA drop brackets, correct? the only thing i would worry about is CV angles Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted February 9, 2006 Share Posted February 9, 2006 the TM lift comes with coil spacers and UCA drop brackets, correct? the only thing i would worry about is CV angles I think it also comes with (should anyway) drop down brackets for the diff too. Link to comment Share on other sites More sharing options...
Casey.T Posted February 9, 2006 Share Posted February 9, 2006 drop down brackets for the diff too and the rear spring spacers are what I would like to get my hands on... Im thinking that it will help to align the cv angles on front and add that extra Lift in the rear with my Calmini -bounce- Link to comment Share on other sites More sharing options...
RedPath88 Posted February 9, 2006 Share Posted February 9, 2006 I think it also comes with (should anyway) drop down brackets for the diff too. From what I remember of the kit, I think you are right... it drops the diff as well and thus does not change CV angles. Only that of the front drive shaft. Link to comment Share on other sites More sharing options...
Maz Posted February 9, 2006 Author Share Posted February 9, 2006 Check out there site they have lots of pics and instructions. I havn't purchased it yet it's at the store and I am going to mexico so I am kinda broke right now and work is slow no OT but I hope to do it by the end of march Link to comment Share on other sites More sharing options...
exodus_68 Posted February 9, 2006 Share Posted February 9, 2006 the problem that arises with this kit is that your torsion bars sit lower and you can have clearance issues. i don't know if this problem has been addressed yet. my 2 cents. Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted February 9, 2006 Share Posted February 9, 2006 the problem that arises with this kit is that your torsion bars sit lower and you can have clearance issues. i don't know if this problem has been addressed yet. my 2 cents. Given the larger tyres that can now be put on the TB's are not an issue. That kit is the best offered on the market today. However, it can not hope to get past the short comings of the Nissan front end. It will last longer than a Calmini lift kit though. Next should be some SLR products just to keep everything in check. Link to comment Share on other sites More sharing options...
solid snake Posted February 14, 2006 Share Posted February 14, 2006 I'm really considering in purchasing this lift. I don't need the shocks since I have enough travel in the pro comps I have. I called rocky montain susp, and was given $700.00 with out shocks. Link to comment Share on other sites More sharing options...
