tmoore4512 Posted September 16 Share Posted September 16 Okay experts, I need to replace my front seal. But the new seal is an absolute nightmare to install... Anyone have any tips? It is wild how difficult this one is. I would appreciate it. Link to comment Share on other sites More sharing options...
Slartibartfast Posted September 16 Share Posted September 16 It's a bit of a pain to get to, but I don't remember the actual seal fighting me too hard. I heated and bent the end of a screwdriver at ninety degrees (like a paint can opener, but thinner), polished the back so it wouldn't scratch the crank (tape over the back of it wouldn't be a bad idea), put a heavy socket over the shaft, slipped the end of the screwdriver between the crank and the seal, hooking the back of the seal, and then tapped the socket against the handle to work the seal out. Took a little screwing around and tapping in different places, but it worked alright. I did the cam seals the same way. I've heard of drilling a hole in the seal, sticking a screw in there, and using the screw as a handle to pull the seal out, but I could just see the drill wandering off into something I didn't want chowdered up. Link to comment Share on other sites More sharing options...
tmoore4512 Posted September 16 Author Share Posted September 16 Getting the old dried out cracked seal out was simple... I am struggling with getting the new one in. Even saturated with grease it is being a pain. Been a while since I have done seals, the cam seals were easy. This little crank seal is...yeah. Link to comment Share on other sites More sharing options...
adamzan Posted September 16 Share Posted September 16 Take an old margarine tub or something like that and cut the side out, roll it up and stick it into the centre of the seal, slide it over the crank and then slide the seal over it and onto the crank. This is how I've always done them. Link to comment Share on other sites More sharing options...
Slartibartfast Posted September 17 Share Posted September 17 I don't remember doing anything special with mine, but that was a while ago. A piece of PVC that fits over the crank might work for a driver tool if you can't get it to walk in. Link to comment Share on other sites More sharing options...
gamellott Posted Friday at 11:48 AM Share Posted Friday at 11:48 AM I believe I used a short piece of iron pipe to drive it on since an oversized socket isn't an option. 1 Link to comment Share on other sites More sharing options...
tmoore4512 Posted Sunday at 03:00 PM Author Share Posted Sunday at 03:00 PM Okay, so I figured out why I was having such an issue. It was the wrong seal. Sigh. 2 Link to comment Share on other sites More sharing options...
gamellott Posted Sunday at 03:26 PM Share Posted Sunday at 03:26 PM That happens. I managed to do that with the rear wheel seals. I don't know how I did it, but I couldn't exactly return them. Took me over a year to actually do the work after accumulating the parts to do the job. So by the time I finally got to it, it was... well just another delay. But then, it was all apart with no real excuse not to get it done. And Then... lets not forget finding debris in the pinion after putting it all back together.... which led to a whole different thread on something that I had never done before Link to comment Share on other sites More sharing options...
Slartibartfast Posted yesterday at 06:32 AM Share Posted yesterday at 06:32 AM That'll do it! Link to comment Share on other sites More sharing options...
adamzan Posted 20 hours ago Share Posted 20 hours ago I had this happen before too. There seems to be multiple seals listed as cam/crank for this engine. I ordered 2 cam seals and they were different, only one fit. Of course they gave me a hard time about returning the one that was wrong. Link to comment Share on other sites More sharing options...
