Guest Posted August 4, 2020 Share Posted August 4, 2020 Are you planning on OME HD front springs PLUS a 1" spacer? That might end up pushing it as you'll see. I currently run OME HD front springs plus a 0.5" spacer and I found that was the max I could go. That was after a year of letting the OME HD springs settle out first.I second this. I am running the exact same setup and 1/2” is near max on oem cv axles. Sent from my Pathfinder Link to comment Share on other sites More sharing options...
zakzackzachary Posted August 5, 2020 Share Posted August 5, 2020 On 8/4/2020 at 11:45 AM, R50JR said: I second this. I am running the exact same setup and 1/2” is near max on oem cv axles. Sent from my Pathfinder Additionally I find this set-up pretty dang good. Only downside is the reduction in downward suspension travel, but that's a function of the heavier duty springs and the fact that we're limited by OEM spec struts (other than maybe OME struts...). 2 Link to comment Share on other sites More sharing options...
PATHYNDH Posted August 9, 2020 Author Share Posted August 9, 2020 (edited) Hey guys thanks for the heads up, as i recall doin research from a year ago . I was trying to achieve having the lift the most possible leveled kit and was told the 1" on the front would be best. Hmmm. maybe i researched wrong. Edited August 9, 2020 by PATHYNDH Link to comment Share on other sites More sharing options...
PATHYNDH Posted August 9, 2020 Author Share Posted August 9, 2020 One last thing before i put the engine back together was i did the drive belts debated about the radiator as well.... Coolant flush right after. I went to Nissan the same day and got a estimate(discount) from Nissan from top to bottom for the hardware for the front and rear lift. RMS next! 1 Link to comment Share on other sites More sharing options...
PATHYNDH Posted August 21, 2020 Author Share Posted August 21, 2020 (edited) So Update, the truck is on the hoist. Transmission removed, will do seals soon (Pics to come)... and YES FINALLY i paid for the front and rear suspension hardware. Every piece from top to bottom from Nissan, but the only part that i didn't buy yet are the bump stops. Are u kidding me almost $250 after tax CDN for both sides and that's with my dealership discount lol none to less lift finally coming soon, now have to decide on what length spacers to use up front hmm Storing at shop Edited August 21, 2020 by PATHYNDH 1 Link to comment Share on other sites More sharing options...
PATHYNDH Posted August 30, 2020 Author Share Posted August 30, 2020 Update, so for the past week and half. the truck been slowly worked on, sitting on the hoist. Removing parts when i can come in, been getting help from the shop, Nissan Seals/Gaskets been a waiting game as we go along and see things that are needed Week ago, i installed these new belts lol off they come again to remove upper oil pan Under Carriage was pretty clean in turn made the removal of parts much easier Rear Main Seal This crush washer above the RMS was probably the longest wait Cleaning the upper oil pan and lower Box of hardware for the lift top to bottom. All Nissan parts except rear bump stop TO BE CONTINUE...... 3 Link to comment Share on other sites More sharing options...
01Pathmaker Posted August 30, 2020 Share Posted August 30, 2020 Wow, must be nice having that kind of workspace available and a clean undercarriage to work on!! I'm currently doing my front suspension overhaul (due to a snapped coil) and so far I have about 12-14 hours into it. Almost every fastener has needed to be heated with the torch, backed off with a HD impact gun, most bolts have needed to be heated and beaten out. Luckily I have a decent size garage with a decent arsenal of tools, but the rust and corrosion is beating the hell out of me! 2 Link to comment Share on other sites More sharing options...
PATHYNDH Posted August 30, 2020 Author Share Posted August 30, 2020 3 hours ago, 01Pathmaker said: Wow, must be nice having that kind of workspace available and a clean undercarriage to work on!! I'm currently doing my front suspension overhaul (due to a snapped coil) and so far I have about 12-14 hours into it. Almost every fastener has needed to be heated with the torch, backed off with a HD impact gun, most bolts have needed to be heated and beaten out. Luckily I have a decent size garage with a decent arsenal of tools, but the rust and corrosion is beating the hell out of me! Ya totally hear ya...Ive known this buddy for like 20 years never have in my years and tons of cars I've owned have i used his option to use his shop til now. Well especially not this extensive. Ya it makes a huuuuuuuuuuge difference not having heavily rusted parts. Hey man at least u have all that, space and tools. I'm a home mechanic with cheaper brand tools, the other benefit is being here i'm surrounded with snap on tools if i need it and advice/help if needed. Good luck on the suspension overhaul guess PB blaster wont work, heat it is ha 1 Link to comment Share on other sites More sharing options...
PATHYNDH Posted September 3, 2020 Author Share Posted September 3, 2020 (edited) FINALLY!!! put the truck back together, also changed the steering rack bushing since it was off, also had front and back sway bar links/bushing on hand for awhile. Did those too. NRC9447 Thought about getting longer Bilsteins, but for now will use the pair i bought a year ago from a fellow Npora local member on here. 5100 (185509) Will coat the wheel wells later on Orangy Spacer didn't come in on time, didn't bother using one but added the 1" SF Creations spacer Front 2928 OME HD Coils on KYB Struts All OEM Nissan Hardware Even with the 1" spacer in the front, still a bit of a rake but will wait for it to settle and then also do the alignment BEFORE AFTER :););) Me and a fellow techs 4Runner Edited September 3, 2020 by PATHYNDH 3 Link to comment Share on other sites More sharing options...
PATHYNDH Posted September 3, 2020 Author Share Posted September 3, 2020 On 8/4/2020 at 11:45 AM, R50JR said: I second this. I am running the exact same setup and 1/2” is near max on oem cv axles. Sent from my Pathfinder So guys i ended using my 1" SF spacer and seem to be fine but will see... Link to comment Share on other sites More sharing options...
PathyGig12 Posted September 3, 2020 Share Posted September 3, 2020 Looks great man. Bold move on the spacer, I know it would messing with my head constantly knowing they were on there but hopefully you get lucky and it works out with your set up. Have you tried turning the wheels by hand while the truck was in the air to see if there’s any binding? Or how about at full lock? Link to comment Share on other sites More sharing options...
Fonze311 Posted September 4, 2020 Share Posted September 4, 2020 (edited) Looks good man! I see the rake you’re taking about, but it’s not really all that bad. Any idea the weight of your front bull-bar bumper? If you still prefer to level it, maybe add a tow hitch in the rear if you don’t already have one? Edited September 4, 2020 by Fonze311 Link to comment Share on other sites More sharing options...
Guest Posted September 4, 2020 Share Posted September 4, 2020 That’s what I’d keep an eye on. The strut looks to be lined up with the knuckle and the inner boot looks to be stretched a bit. Keep in mind the 2928 springs hardly compress with vehicle weight so you’ll be running near that angle all the time, especially during acceleration. Post a pic of the front view of cv axle. Sent from my Pathfinder Link to comment Share on other sites More sharing options...
Kazza Posted September 7, 2020 Share Posted September 7, 2020 What rims are those you are rockin @PATHYNDH? Link to comment Share on other sites More sharing options...
R50ATL Posted September 9, 2020 Share Posted September 9, 2020 On 6/9/2020 at 2:39 AM, PATHYNDH said: TONs of goodies!!! Some for now some for later preventative maintenance in bulk (shout out to Rock Auto) lol. Engine was next up, Installed new battery as well , SMP 2G Negative battery cable (felt like previous one was a bit to short? Also added short ram intake, direct fit with the adapter. Since i was in there i then changed the spark plug's as well. Will eventually do all the gaskets down the road for preventive maintenance Where did you get the adapter for the air intake? 1 Link to comment Share on other sites More sharing options...
RainGoat Posted September 10, 2020 Share Posted September 10, 2020 Wow, lots of work! Looks Great. Personally, I think a half inch of rake sounds perfect. 1 Link to comment Share on other sites More sharing options...
taberwit Posted September 18, 2020 Share Posted September 18, 2020 Certainly a lot of sweat equity into this beauty! There's no better feeling than being surrounded by the evidence of your own hard work! Thanks for sharing! Link to comment Share on other sites More sharing options...
DesertKyle Posted September 18, 2020 Share Posted September 18, 2020 Did you have to drop both oil pans to do the rear main seal? Any tips for the job? Haven't researched it yet but I've gotta do mine soon, trying to wait till I find a decent trans to swap at the same time though. Link to comment Share on other sites More sharing options...
HoustonVA Posted November 24, 2020 Share Posted November 24, 2020 Jesus man, you're an absolute maniac. Nice work. fskcin wow. Link to comment Share on other sites More sharing options...
PathyGig12 Posted November 25, 2020 Share Posted November 25, 2020 On 9/9/2020 at 4:10 PM, R50ATL said: Where did you get the adapter for the air intake? I’d love to know this as well! Link to comment Share on other sites More sharing options...
Dbot Posted November 30, 2020 Share Posted November 30, 2020 On 8/30/2020 at 1:26 PM, PATHYNDH said: Ya totally hear ya...Ive known this buddy for like 20 years never have in my years and tons of cars I've owned have i used his option to use his shop til now. Well especially not this extensive. Ya it makes a huuuuuuuuuuge difference not having heavily rusted parts. Hey man at least u have all that, space and tools. I'm a home mechanic with cheaper brand tools, the other benefit is being here i'm surrounded with snap on tools if i need it and advice/help if needed. Good luck on the suspension overhaul guess PB blaster wont work, heat it is ha I’ve totally daydreamed about this before. Throwing a bunch of oem parts on mine for a deep overhaul in a shop. Just curious what’s the plug and crush washer above the rms for? Link to comment Share on other sites More sharing options...
