This car just keeps on enduring.
It's hardly been used since our son was born 18 months ago, so I listed it for sale.
(I have a dual cab D22 now)
My wife found out and told me I had to keep it, and in hindsight I see that she knew I wasn't ready to move her on.
So, the old girl gets another reprieve.
I am going to make a more concentrated effort to use and enjoy her, as well as fix a few of the small niggles that I have allowed to creep in.
Edited by FirstGenFreak
That didn't exactly go as planned.
Took her out Saturday and had a big end bearing or gudgeon pin failure, so time for a rebuild or heart transplant 🙄
So, I pulled the original Z24 out from under my bench.
This was a runner, but smokey when I swapped it almost 20 years ago.
One piston (#3) had bad rings and ring lands.
Bores however, cleaned up nicely with a hone.
Waiting for parts now.
Will get new pistons, rings, bearings, timing chain/tensioners, oil pump. Have a reco head here on the shelf.
The KA24DE swap can wait for now.
My parts hoard has saved me several times lately. Torsion bars for my Xterra, one let go. Found I had a nearly new oem set I bought off of a guy 15 years ago who fitted aftermarket bars on his. Perfect, free repair!
Fan clutch went on the X, ripped the one off my old 94 wd21 that wasn't that old, it looked the same so I put it on. :D
  • 3 months later...
Finally ordered the last of the engine parts today, time flies and I miss driving this thing more than I thought I would.
I went camping over the Xmas break in my D22, it felt like such a betrayal after all these years!
Crank and new main bearings in the big Z24 over the weekend, main bearing clearances and thrust all measured up great.
Pistons, rings and new clutch turned up last night
I just need to get the pistons pressed on and then I am ready to assemble.
Can't wait to have my old girl going again!
Still waiting for my pistons and rods, but decided to lift the old lump out.
Last time, I pulled the trans, this time I thought I'd try the method of removing the front diff.
Way easier than dropping the trans, but I will be honest - I am getting too old for any of this 😁
After having done this 3 or 4 times on Xterra and WD21 I'd agree pulling the diff is much easier than wrestling the transmission back far enough, because I also had to pry the torsion bar xmember down or just remove them.
Yeah, I've pulled the trans to do it before, it is a whole ordeal, plus I fitted a reconditioned trans a few years ago, not in a hurry to remove it again!
