PathyGig12’s Build Thread
PathyGig12
47 minutes ago, BrettNature said:
Thanks so much for getting back to me! I do have someone local fabricating the roof rack for me. However, I am still curious if you recall the brand name or part number to share my ideas. I seem to be finding more designs for the Xterra for some reason?
http://www.nissanpathfinders.net/forum/topic/44771-diy-roof-rack-platform/
  • 1 month later...
Minor update
On my last visit to Vegas the brake booster failed randomly so we had to put in a new one. Luckily the master cylinder is still in good shape and now it works perfectly again. Well “perfectly” is not a great word to describe a loaded down truck with front brakes that are too small to begin with and  rear drums that do almost nothing, but hey, at least the booster assist is back now. I’d love to do a rear disk conversion but it’s just way too involved for me at the moment, and I’m not ready to pay a shop hundreds on top of parts. Maybe someday
The other big news is that I think I finally cracked the code on that weird vibration I was having up front. It turns out that the CVs are still turning when the hubs are unlocked, which explains a lot. That opens up other possibilities rather than only being the transfer case. I’ve narrowed it down to two options: either it’s one of the new CVs I put in that’s bad from the factory, because the vibration started after they went on (I originally ruled it out because I thought the hubs were completely bypassing them), or it’s the front shaft u-joints, which again I originally ruled out. The last thing I’m going to try is switching to mile marker hubs instead of the warns, because it’s possible that the warns are not properly disconnecting the CVs from the wheels somehow. No reason not to give the MMs a shot, I can always return them if they don’t change anything for the better.
Like I mentioned in a previous post, the vibration disappears when you’ve been driving around 80mph for a few minutes, and stays nonexistent until you turn off and restart the truck, and it coincides with a 4wd light on the dash that comes on shortly after the vibration disappears. This tells me that what might be happening is the CVs finally disconnect once you’re going fast, and the transfer case starts to freak out about the lack of front shaft rotation, throwing the light. That’s my theory anyway, so changing the hubs might help clear things up.
Not sure if it makes any sense, but that’s what I feel might be happening. Either that or its coming from the transfer case side, and the CVs are turning because of some movement in the case which shouldn’t be possible in 2wd mode. That’s the only other way the CVs could be moving while the hubs are unlocked. Either the hubs aren’t working properly or the Tcase isn’t. And the vibration itself must be the result of the messed up front shaft or bad CV that’s forced to rotate when it’s not supposed to be.
The truth is, if I fixed the vibrating part itself, I could probably ignore the CV engagement altogether, but I feel like that defeats the point of the manual hubs if they don’t disconnect the CVs, so I really want to figure out why they're still turning. I’d rather stop the rotation than fix the vibration, because in 4wd (when I need the CVs and front shaft turning) the speed is low enough to not feel the vibration anyway, so it’s a non issue. One less thing to fix
Minor update
The front still spins with auto transfer case, this is normal. Your hubs are probably working fine. Cv shafts are fine. I’d learn to live with it.
Sent from my Pathfinder
You got a source for that? I can’t imagine why the front would still be spinning with the truck in 2wd and the hubs unlocked? I’ve always been under the impression that the front shaft was spinning passively just as a result of the factory hubs being locked at all times, but only powered by the Tcase in either auto mode or 4wd.
I’d love to be wrong about this though
I’m not sure anyone knows the static load rating for the Pathfinder, I believe the dynamic load rating is 100# though many of us have exceeded that with regularity. To stand up there consider adding FarmTek chicken coop flooring-it’s a common mod in Land Rovers.
No source since the auto tcase wasn’t designed to be used with manual hubs. I believe the reason is because it uses clutches that have a bit of drag in 2wd.
Hmm, that does make sense. But again, doesn’t that make the manual hubs almost pointless? If they don’t remove the CVs from the equation, then how do they offer improved mileage and all the other benefits?
And really, if that’s true about the clutches  then the vibration makes even less sense because it shouldn’t disappear after a few minutes at 80mph and remain gone AT ALL SPEEDS until the truck is restarted. If the clutches are dragging on the front then there shouldn’t be a way for them to disengage completely, regardless of the conditions. Like you said, it was made for the factory hubs not manual ones. Either I’m breaking the Tcase in some small way every time it happens, or something else is involved.
Anyway, I’ll still try the mile markers just to rule out the hubs and then move on to mounting the underbody camera to see what’s happening at 80mph with the CVs.
These are questions I would love answered. While I personally really like my ATX14A, it seems to remain a bit of a “black box” to me. I too have a set of Mile Marker hubs I kindly was gifted by[mention=36148]hawairish[/mention] but I have to admit I’m given pause by the recent destruction of a set & reports of other failures. I have only heard of OEM auto hub failures in theory but I’m unaware of any actual failures.
Saving a single mpg is inconsequential to me but I see value in preserving wear on the OEM CVs (especially in light of recent discoveries that not all aftermarket CVs fit without binding in cases where the OEMs are fine).
The primary reason for installing manual hubs for me is to allow for a CV replacement on trail without removing the wheel - though I have to admit that, with the kind of offroading I do, I will consider an OEM CV failure to be operator error on my part.
Anyways, more info is great as there doesn’t seem to be much definitive on the ATX14A. The use of an undercarriage camera is an excellent idea.
Well, turns out the mile markers are absolutely no different, the vibration is the same as it was with the warns. At least I ruled out the hubs.
Instead of swapping them back out, I’ll probably just sell the warns and keep the mile markers because they should be plenty strong enough for my purposes and the warns will fetch more used than the MMs cost me brand new. If anyone on here wants the warns, hit me up.
Anyway, this experiment basically confirms that there is something else dragging on the CVs and keeping them turning, so the only options I have now are to fix the vibration itself (front shaft or CVs) or live with it. I might even just keep the hubs locked most of the time since the manual hubs aren’t saving much on gas or CV boot wear. I do still want to keep them for the other benefit of easy changing CVs as Raingoat mentioned
Still need to figure out what happens when the vibration smooths out, so the camera is going on sometime this week and that should clear things up. If it turns out that the CVs stop rotating when the vibration smooths out, itll tell me that the front drivetrain is to blame but also raise more questions about how the Tcase actually works. Because again, I can’t see how he clutch plates could disconnect from the front shaft after 80mph if they aren’t built to ever fully disconnect at all. That screams “breakage” to me
Id like to also mention that on a couple of trails I was getting a constant 4wd light popping up a couple times during slow speed maneuvers or tight turns and reversing in 4 low, but it went away after restarting the truck. This hasn’t happened before, so I’m worried that the clutch plates for the front shaft are being damaged and are getting less reliable engagement of the front than they used to, causing the light to pop up? If so, that would definitely be a reason to avoid manual hubs, but only time will tell. I don’t recall anyone else having any issues like that, but who knows?
Bottom line is this stupid case is a complete mystery and I honestly wish I had a floor shifter instead, even though the auto feature is cool sometimes
Sounds like you need to change your fluids
If you’re referring to the Tcase fluids, they were just changed a couple months ago. No difference before and after.
Here in the PNW, where it is wet all the time, it’s a big bonus to have AWD. I also prefer it for gravel, packed sand & snow as I get 4 wheel grip without the plowing understeer of a licked center. I often forget to put it into 4Hi until I come across something truly challenging & then it’s usually because I actually need 4Lo. The lack of that option is one of my biggest complaints on our 5th Gen 4Runner (Limited models do have it but that’s a whole different story).
I hear you man, there’s no denying the awesomeness of AUTO mode.
But my whole thing is I have no idea how much damage, if any, is being done to the Tcase by running manual hubs. With the manual case I wouldn’t have to worry about it. And I’d definitely trade off a bit of helpful tech to have the peace of mind that my truck won’t be dead in the water
New underbody camera is finally mounted. I went with a hard wire connection to fix the spotty connection issues the last one had, and so far so good. I’ve noticed that the front shaft spins with the wheels at all speeds so far, but I haven’t gone fast enough to get the 4wd error light or get rid of the vibration so I still don’t know what happens to the front shaft when that occurs. Time will tell, and I’ll update when I it happens.
I ended up mounting it to the front of the crossmember that’s between the Tcase and tranny. I love the new spot because it lets me see the front wheels but also under the bumper for when I’m going over hills. And of course the underbody lights make it usable at night as well. My next goal is to shield it somehow so that it doesn’t get killed by road debris like the last one. I’m thinking super clear lexan, but it’s hard to figure out a way to mount the shield effectively or make any sort of box around it because there’s not much room where I put it
10 hours ago, RainGoat said:
A version of this has been in my ToDo list for over a decade. I look forward to copying your final results.
I promise you’ll do it 20 times better than I did lol.
I don’t even bother making the wires look clean and tucked away. I figure I’m always messing with the electrical stuff and adding things so it’s easier to leave them in temp positions than to dig under panels every time I decide to move or add something.
Just started buying parts for a minor engine “overhaul”. Super excited to finally get started on this. I’ve been planning it for a while now, doing a lot or research on parts, locations, and how to do different jobs properly. A lot of this stuff is pushing its limit of reliability and I road trip a lot so I need the peace of mind of the preventative maintenance. I’ll be doing:
*Takes deep breath*
MAF, IACV, plugs, injectors, fan, radiator, fan clutch, water pump, starter (solenoid is starting to stick), Thermostats, upstream O2 sensors, fuel pressure regulator, PCV, coolant temp sensor, knock sensor, valve cover gaskets, spark plug tube seals, cold air intake, and replacing worn vacuum hoses. Probably a few things I forgot but yeah that’s most of it. I’ve got a few things already on order but still saving for the rest.
The other thing I’m looking at is having the timing chain replaced. Not sure if it’s worn or not but at 280K it must be right?
Oh yeah and I’m going to try making a trailer with one of the axle kits they sell online. It’ll be nice to load it up with spare parts and camping gear for longer trips rather than clutter the cargo area of the truck itself
On 8/23/2020 at 7:14 PM, PathyGig12 said:
Does anyone have the part numbers for the two thermostats? When I do a search I can’t discern which is which.
Nissan Part No.:21230-8P300 - VALVE ASSY WATER CONTROL is the rear "thermostat"
Nissan Part No.:21200-4W010 - THERMOSTAT ASSY  is the thermostat on the front of the engine
Sorry I didn't see this sooner.  Hope that helps!
  • Thanks 1
u beat me too it lol If u ever need parts number i also use infintipartsdeal.com it basically breaks down all components and part numbers :)
Edited by PATHYNDH
Anyone know whether the grill from an SE will fit an LE? I’m thinking it probably should as long as it’s a post facelift R50, but not sure.
My grill is peeling and cracking and looks terrible, and I love the look of the SE grill so it would be nice if it fit
9 hours ago, PathyDude17 said:
All post facelift grills are the same mounting. I had an 03 SE but swapped to the honeycomb no problem. Just try not to break any of the plastic clips when removing the grills.
Awesome thanks, that’s what I was hoping
This is the one I’ll most likely go for
https://www.carparts.com/details/Nissan/Pathfinder/Replacement/Grille_Assembly/2001/N070101.html?TID=gglpla&origin=pla&utm_source=google&utm_medium=pla&utm_campaign=9089238399&gclid=Cj0KCQjw-af6BRC5ARIsAALPIlUtShFHmvJ1XQFmCshPGTZKD3uc891BF419i9ec1fVGfsoSin_u9b4aAmzNEALw_wcB&gclsrc=aw.ds
