01 Pathy Dash lights
Does anyone have an idea on my dash lights, speedometer, tach etc,? I've checked the fuses and nothing is blown. What are the chances that the bulbs themselves blew? The only thing on my dash that works is the clock. Any advice is welcomed!!
Thanks guys!
You lucky, lucky barstard, your clock works. Mine hasnt for years. And YES ABSOLUTELY, is the answer to your Q. Dude yer truck is 16 y/o. How many lights have seen last 16 years? Pull yer dash cluster out (plastic removal tools are an asset) and yer heater knob panel too and replace all of them. They're slightly larger than a TicTac. I think my cluster took 7 (maybe more), idiot lights incuded. My Check Engine was on for so many years that it burnt out-lol. Dedicate a full afternoon to do it- just the dirt behind everthing alone will blown yer mind. Dirt attracts moisture and moisture attracts electrical problems...just sayin. Good luck, V
The right side (tech and temp) gauges on my truck wouldn't light up so I popped the cluster out and I barely even touched the bulb and it kit up, I guess I'd had come loose a bit, might be your case too, it's not difficult to get it out. If that's not it I'd check the dimmer switch like the dude above me said.
Fix your clock: http://www.nissanpathfinders.net/forum/topic/29248-how-i-fixed-my-digital-dash-clock/
