IACV Gasket? 3.3 97 Qx4
Mrelcocko
Installing a new gasket on my idle air control valve and wondering if I need to use RTV sealant or put it on dry?
Sent from my SM-G530T using Tapatalk
Edited by Mrelcocko
I would think dry is fine. Only reason I ever put rtv on gaskets is for extra leak protection from fluids. I guess air is a fluid, but I don't think it would need it.
cut mine out of a gasket making kit i got local. got my iacv from a wrecking yard. 20bones instead of over 100.
also deleted the hose to the thermal element since mine hasnt worked in a million yrs and was leaking
well did a bypass loop i should say.
p.s. no rtv on gasket, works fine
Edited by fixinto
