joserabagojr Posted March 12, 2017 Share Posted March 12, 2017 Hello NPORA nation! I need help. I am currently the 3rd owner of a 97 Nissan Pathfinder, and I don't know the car radio history of the car. Curently the car is using a Old 2004 Pioneer Single Din Radio, running a 2000watt Planet Audio Amplifier, with Dual 12 Subs. I want to upgrade to a double din w/ bluetooth and a backup camera, and my question: Can a double din fit on a 1997 Nissan Pathfinder? If you could answer soon, and provide the correct harness to come with the double din that will be great!! Thank you, Jose Link to comment Share on other sites More sharing options...
Citron Posted March 12, 2017 Share Posted March 12, 2017 Check out crutchfield. Put in your vehicle and it will give all the radios that fit, plus the needed harness and instructions. Link to comment Share on other sites More sharing options...
Remus92 Posted March 12, 2017 Share Posted March 12, 2017 I think it should. Given the space available in my 96. Link to comment Share on other sites More sharing options...
XPLORx4 Posted March 12, 2017 Share Posted March 12, 2017 (edited) Yes, a double-din HU will fit in a '97. I have a Pioneer NEX8000 installed in my '97 LE and it's fantastic. You'll need this, too: https://www.crutchfield.com/p_120707550/Metra-70-7550-Receiver-Wiring-Harness.html?tp=2977 Edited March 12, 2017 by XPLORx4 1 Link to comment Share on other sites More sharing options...
Mbrianc Posted March 13, 2017 Share Posted March 13, 2017 A word of advice though. I have a backup camera in my 02, and none of the wireless transmitters I used would work worth a damn. If they would connect, the picture quality would suck. I finally hardwired the video, and wished I would have done that in the first place. Would have saved me some time and money. Sent from my Nexus 5 using Tapatalk 2 Link to comment Share on other sites More sharing options...
jyeager Posted March 13, 2017 Share Posted March 13, 2017 Yes, a double-din HU will fit in a '97. I have a Pioneer NEX8000 installed in my '97 LE and it's fantastic. You'll need this, too: https://www.crutchfield.com/p_120707550/Metra-70-7550-Receiver-Wiring-Harness.html?tp=2977 Crutchfield sells stereo-specific harness adapters. I have a Sony and bought a harness that adapts Nissan to Sony. Your adapter harness will depend on the brand of stereo you choose. Link to comment Share on other sites More sharing options...
XPLORx4 Posted March 13, 2017 Share Posted March 13, 2017 All of the aftermarket head units I have purchased had stripped wire ends which I then soldered and heat-shrinked to the Metra vehicle-specific adapter. So, you don't need a HU-specific adapter if you know how to solder. If you don't know how to solder, you can use crimp-connectors and electrical tape, but they're not usually as reliable. Link to comment Share on other sites More sharing options...
whatchugot12 Posted March 13, 2017 Share Posted March 13, 2017 Double din! Sent from my SAMSUNG-SM-G900A using Tapatalk Link to comment Share on other sites More sharing options...
jyeager Posted March 14, 2017 Share Posted March 14, 2017 All of the aftermarket head units I have purchased had stripped wire ends which I then soldered and heat-shrinked to the Metra vehicle-specific adapter. So, you don't need a HU-specific adapter if you know how to solder. If you don't know how to solder, you can use crimp-connectors and electrical tape, but they're not usually as reliable. Ah, I believe that's correct. My memory is fuzzy and I didn't remember where my stereo side harness came from. I did the soldering/shrink wrapping thing. Thanks for the correction. Link to comment Share on other sites More sharing options...
Blindaviator Posted March 15, 2017 Share Posted March 15, 2017 https://www.amazon.com/dp/B000K50GF4/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=2NOVE80SOPN7M&coliid=I38LG764C6VCPX&psc=1 Link to comment Share on other sites More sharing options...
Gusthebus Posted March 15, 2017 Share Posted March 15, 2017 https://www.amazon.com/dp/B0002BG6B4/ref=cm_sw_r_other_apa_DLvYybK0JKRKG Link to comment Share on other sites More sharing options...
