Exhaust Manifold Replacement
Brad251
Need some input on my dilemma. I have an 88 SE V6 path. The pass side manifold needs replacing ( its very loud and possibly cracked ). Problem is I took it to a very reputable shop and he basically said that there are so many unknowns that it's probably not worth fixing. IE: broken studs , possible head removal and all the nightmarish things you will probably run into trying to replace a manifold on a 27yr old truck with 200K plus miles. Esp since I don't have a lot of money in the truck. Any suggestions ? Thought about maybe trying to get it welded but even the best welders have trouble with cast plus you got the temp getting hot and cold. Any thoughts ? I have already purchased all the parts. Thanks
Sent from my XT1585 using Tapatalk
