timing belt tensioner
vagabond
anyone know if the stud that the tensioner bolts to is screwed in or pressed fit the one on my 88 broke.
haven't pulled the heads yet to see what damage there is to the pistons, hopefully nothing bad
yea, broke mine off and had to drill it, tap it and used a bolt instead of a stud/washer/nut
it's the little bump to the right of the tensioner :)
Edited by k9sar
yeah I was going to pull one out of a spare block and I was afraid I was going to snap it off. guess I'll pull the heads an check the pistons if theyre ok I'll go ahead and drill it out
