fbccars924 Posted August 4, 2015 Share Posted August 4, 2015 Ok, so I have been on Car-part.com looking for a Tcase for my 95 (9/94) pathfinder, and every time I look it up it asks if my production date is <3/95 or >4/95. What is the difference? Partially bc there is a >4/95 tcase for $50 not far from me where as the cheapest <3/95 are ~$175. Is there a major change in 95. Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 7, 2015 Share Posted August 7, 2015 If there is, this is the first I've heard of it. Link to comment Share on other sites More sharing options...
adamzan Posted August 8, 2015 Share Posted August 8, 2015 They should all be the same. I'm running a t-case out of a 2002 Xterra in my pathy... Link to comment Share on other sites More sharing options...
tmoore4512 Posted August 14, 2015 Share Posted August 14, 2015 (edited) Yea no doubt, they are the same...I have an 02 X transfer case in mine right now...same EXACT thing... Edited August 14, 2015 by tmoore4512 Link to comment Share on other sites More sharing options...
Lemay Posted August 14, 2015 Share Posted August 14, 2015 (edited) all WD21 and wd22 have the same exact t-case I buy dangerous truck to drive sometime to part it out and all wd21 and wd22 that i cut into pieces has the same trans and t-case R200a identical minus the flange, i think the front d-shaft are the same too i have few in stock lol Edited August 14, 2015 by Lemay Link to comment Share on other sites More sharing options...
tmoore4512 Posted August 16, 2015 Share Posted August 16, 2015 The second line? I am sort of confused what you were sayin bra... Link to comment Share on other sites More sharing options...
Lemay Posted August 18, 2015 Share Posted August 18, 2015 (edited) sorry.... i buy dangerous nissan from my friends, truck that the frame is too far gone but they still drive it on the road lol, like cracked winshield because the body is actualy supporting the frame and so on.... I chop them in pieces and stock the good stuff in a shed. not on the internal but only from the exterior and mounting point, all wd21 and wd22 has the same drivetrain setup. Trans, T-case, steering box... alot of the same stuff. Edited August 18, 2015 by Lemay Link to comment Share on other sites More sharing options...
tmoore4512 Posted August 18, 2015 Share Posted August 18, 2015 That makes way more sense...sorry for the confusion! Link to comment Share on other sites More sharing options...
Precise1 Posted August 18, 2015 Share Posted August 18, 2015 LOL ESL... Speak French to him. (Quebec ) B Link to comment Share on other sites More sharing options...
Lemay Posted August 18, 2015 Share Posted August 18, 2015 (edited) i realise that sometime i'm really poor in english lol Edited August 18, 2015 by Lemay Link to comment Share on other sites More sharing options...
tmoore4512 Posted August 18, 2015 Share Posted August 18, 2015 Well I guess that makes PERFECT SENSE now. Haha... Link to comment Share on other sites More sharing options...
adamzan Posted August 19, 2015 Share Posted August 19, 2015 i realise that sometime i'm really poor in english lolBetter than a lot of the Americans on here. Sent from my SGH-I747M using Tapatalk Link to comment Share on other sites More sharing options...
Lemay Posted August 19, 2015 Share Posted August 19, 2015 lol... tanks! if someone can refresh my memory, the chain in the TX10 is wider in the 2door than the 4door/xterra... right? Link to comment Share on other sites More sharing options...
tmoore4512 Posted August 20, 2015 Share Posted August 20, 2015 I believe that they use the same chain. The TX10 is a TX10. The TX12 had larger internals but is a totally different gearbox.I could be wrong (usually am) but I took the current TX10 from the 2002 Xterra apart (split the case) to make sure all was well, and to re seal it before install...and it did not appear to be any different than my 95's TX10.The ONLY difference to report is the shift linkage for the gearbox. But it was a different arm rather than anything internal. Simple fix. Link to comment Share on other sites More sharing options...
MY1PATH Posted August 20, 2015 Share Posted August 20, 2015 87-95 WD21 & D21 Pathfinder and Pickup00-04 WD22 & D22 Xterra and FrontierThey all fit the same BUT THERE IS A DIFFERENCE...In the early 90's they started running a narrower chain. (everything else internally is the same just the chain is different)The narrower chain only effects the most hard core rock crawlers with lockers and T-case gears And those who get airborne a lot in 4 wheel drive... <if you are one of these two the narrower chain stretches faster (It was $400 from Nissan).But for everyone else the chain should last a lifetime. Link to comment Share on other sites More sharing options...
Lemay Posted August 21, 2015 Share Posted August 21, 2015 ok, tanks! Link to comment Share on other sites More sharing options...
tmoore4512 Posted August 21, 2015 Share Posted August 21, 2015 I stand corrected. Link to comment Share on other sites More sharing options...
