k9sar Posted April 13, 2015 Share Posted April 13, 2015 95 pathy SEV6 Before I dig through the FSM and do troubleshooting, thought I'd check with the masses and see if anyone has the easy/quick answer. The ABS idiot light on my instrument panel is on. My fluid was a little low but not below the minimum level on the reservoir. I topped off the brake fluid but the ABS light is still on. Anyone else have this happen and what was the cause? Just trying to save myself some diagnostic time cause I'm old and lazy. Link to comment Share on other sites More sharing options...
RedPath88 Posted April 13, 2015 Share Posted April 13, 2015 Check the connector at the axle input shaft to see if it is loose or wet? Link to comment Share on other sites More sharing options...
adamzan Posted April 13, 2015 Share Posted April 13, 2015 In the FSM there is a diagnostic thing where you ground out one of the pins on that connector that hangs out near the fuse box. It makes the abs lights flash. There are codes you can pull from it. I did it on mine, was fairly easy and told me I had a bad sensor in the rear end. Link to comment Share on other sites More sharing options...
k9sar Posted April 13, 2015 Author Share Posted April 13, 2015 k. thanks. I glanced at the diagnostic and saw the connector ground but didn't read much more because the family came home and I had to put my toys away and do yardwork. Link to comment Share on other sites More sharing options...
k9sar Posted April 13, 2015 Author Share Posted April 13, 2015 I can't imagine the rear ABS is necessary for normal function though I wonder if they will pass it for inspection if there is an indicator of a problem with the brake system. hmmm... do I fix it with a piece of black electrical tape over the indicator or do I really look into the issue...???... hmmm...... Link to comment Share on other sites More sharing options...
adamzan Posted April 13, 2015 Share Posted April 13, 2015 If you unplug the abs computer frfrom under the drivers seat the light will go off. 1 Link to comment Share on other sites More sharing options...
RedPath88 Posted April 13, 2015 Share Posted April 13, 2015 Sounds like pulling the codes is not that hard, might as well check it out. Link to comment Share on other sites More sharing options...
Precise1 Posted April 16, 2015 Share Posted April 16, 2015 Also, sometimes it just needs to be bled. Simon and I both had ABS lights that were 'fixed' that way. Threads are here somewhere... B Link to comment Share on other sites More sharing options...
