Anyone doing a Solar system?
Azbuilt
Well, you can go pretty cheap like this...
http://www.harborfreight.com/45-watt-solar-panel-kit-68751-8527.html
http://www.wholesalesolar.com/products.folder/battery-folder/upg-ub-121100.html
or http://www.batterystuff.com/batteries/upc-telecom/UB12900-45826.html
or http://www.batterystuff.com/batteries/upc-telecom/UB12750-45821.html
to have a little bit left over for some cables/mounting and making a wooden travel case for the panels (preferably something that doubles as a stand or can be mounted to your roof for shade). ;)
Exactly!!
Even in AZ (not too far from here), I believe you want a 15 degree inclination to be perpendicular to the light rays, and want to track orientation during the day as well...
Point is, there is no plug and play closer to what I pointed out, assuming you need another battery to hold it all (don't bother with a 1 battery system) for the cost you mentioned.
Solar has gotten cheap, but not that cheap...
I'm considering a couple of these to charge a couple of batteries just for emergencies. Well under $1k and you have a basic system that can be split between home and trail. ;)
All good info on here, otherwise I've seen some really well-written threads on ExPo taking care of the issue on vans, Land Cruisers and the like going on long expeditions. Being in the Sun Belt you should have no problem with the energy, fabbing up a small mount and aiming system should be no problem. GoalZero makes some handy chargers and kits for iphones and the like, but it sounds like you want something a bit more powerful. Still might be worth checking out.
Nice, yeah soon as my bumper project is done. Solar system and lighting will be on the agenda. Thank you all for the information figured I am not the only one that has thought of this.
A good source for info would be Van Dwelling. Van Dwelling sticks in my mind because there was a write up on installing solar panels. There are other sites that deal with living out of a van or small vehicle that are also pretty good. This type of living is all about making the most with the least amount of space, and doing it as cheaply as possible.
We have "solar farms" popping up every where around here now. If they aren't on trackers they at least point S/ SW. I have two tiny panels (8 and 40 watt). If I'm home daytime I'll swing mine from east to west during the day, if not they point S/W all day. I don't want to sound stupid (hard not to) but I've never seen a sun rise and sun set in Arizona. But I will say thanks to you guys I see pics... world wide pics.! Thanks KJ.
Edited by kdj
  • 5 years later...
I have a solar set-up. I know this is an older post though.
Mounted on the roof, utilizing the existing roof rack, I have a Goal Zero - Boulder 100 solar panel mounted with brackets of my own design.
This feeds into a Goal Zero "Yeti" "Power Station" that I keep in the back to power various stuff.
Does it work well for you? Have you had any problems and would you do anything differently if done again?
BTW there's no issue with reviving old posts. Honestly it helps keep related info together :Aok:
  • 3 weeks later...
I picked the Goal Zero - Boulder 100 because it was the largest panel that would fit in the roofrack. For that, I like this product. I can also remove it and set it up on it's stand. Or stand it up on my roof. It's built pretty tough, so it'll last for years being mounted, and dismounted, and used for camping, etc. For performance wise, not so much. I seem to be getting 40 to 60 watts regularly, and only on the best clearest summer day with the panel pointed directly at the sun, can I get something in the low 80 watt range.
Because it's powering a Goal Zero Yeti 400, I sometimes need more power, as I don't have much in reserve. So to get more wattage out of the panel, I loosen my mounts, and stand up the panel. This probably wouldn't be needed if I had more batteries connected. (Which I've ordered).  The Yeti 400 (non lithium) is a 300 watt inverter on a 33ah battery, so if I'm using a laptop, running a 12v fridge, charging phones and cameras, I can drain the thing entirely while working in the sun in something like 4-6 hours. doing the math, you can use 100 watts for 4 hours "400 watt hour" is the rating of the Yeti 400. So even with 40-60 watts coming in, if I'm pulling 180watts, I'm running out of power in the day time. But that's kinda heavy use working on the road.
My rack mount? Isn't the best. The first one that I designed would have been AWESOME, but became cost prohibitive. But I still want to make it. So for the time being, I bought some angle Aluminium and by making several cuts, bends, and holes, it works for mounting the panel. So I spent about $40 instead of hundreds. However, the location of the roof struts are critically dependent to be placed at exact locations for these brackets to connect and mount up.
I plan to make a video later covering all of this, so any questions now that i can try to answer typing would be good for preparation.
