Bubbley11 Posted September 8, 2014 Share Posted September 8, 2014 So my fifth gear bearing went too long without me looking for the overfill thread. So I think I will be in need of a new one soon. I want to swap a 96+ one in that is a manual, if I can find one. What a I want is the 1-3 gears, in my old one, in the new one and the 4&5 to be the new ones. As the new one has a smaller ratio. Can I swap them or are they different width's? I want my crawling gears but it might just be better to just swap the tranny. So what do you think am I crazy or just itching to screw something up? Link to comment Share on other sites More sharing options...
Nefarious Posted September 14, 2014 Share Posted September 14, 2014 I would personally just swap in a nice good shape 96+ model trans if it were me. Just my 2 pence Link to comment Share on other sites More sharing options...
Bubbley11 Posted September 14, 2014 Author Share Posted September 14, 2014 Are the gears that different? Just wondering Link to comment Share on other sites More sharing options...
Precise1 Posted September 15, 2014 Share Posted September 15, 2014 (edited) I'm not sure if that gearing info is in the FSM, but it seems like it would be, somewhere. I'd start by downloading the 1996 or 1998 FSM and searching for the information... As for wider, they bolt up the same at the bell housing and those trannys take the same TX-10 transfer case so it seems like that should be the case, I just can't prove it. B Quite a few people swapped in autos from R-50s and Xterras and they lined up, so it would almost have to be the case that the manuals are the same... Edited September 15, 2014 by Precise1 Link to comment Share on other sites More sharing options...
CO_pathfinder Posted November 18, 2014 Share Posted November 18, 2014 4&5 to be the new ones Double amen to that. I know your pain with 5th gear.... stupid 55mph national speed limit law ruining final drive ratios from 83 to 95. Don't you just hate that 4th to 5th is only ~ 500 rpm different? And 75mph is 3500 rpm By the way, the actual gears themselves in the 96 are the same width as the WD21 gears. Link to comment Share on other sites More sharing options...
adamzan Posted November 18, 2014 Share Posted November 18, 2014 Maybe with your little XE sized tires. Mine is turning less than 3k rpm at 120km/h Link to comment Share on other sites More sharing options...
Harbinger Posted November 19, 2014 Share Posted November 19, 2014 I'm in the middle of swapping a 1998 R50 5 speed into my truck. Bolt patterns are the same on both ends, but have no idea if the gearing is different. Link to comment Share on other sites More sharing options...
Bubbley11 Posted December 2, 2014 Author Share Posted December 2, 2014 (edited) Well I'm starting to get a whine in every gear but 4th now. I over filled it which I thought would save the others but I think it's on it last leg. I'll have to find a 96 or newer 5spd after winter. No viable leaks from it so I think the PO just never over filled it. Edited December 2, 2014 by Bubbley11 Link to comment Share on other sites More sharing options...
