txpath4x4 Posted May 13, 2014 Share Posted May 13, 2014 Hey guys I have had a slight erratic miss until the engine temp gets normal since I have owned it . Any ideas? I've just got through doing the timing belt and hoses etc. Do I have a ghost problem? Link to comment Share on other sites More sharing options...
xylicon Posted May 13, 2014 Share Posted May 13, 2014 My 94 does this too, especially on cold mornings. It will run rough for about 10 seconds and then start to clear up and then be fine for the rest of the day. Link to comment Share on other sites More sharing options...
byob Posted May 13, 2014 Share Posted May 13, 2014 (edited) Multiple possibilities. On cold starts is when the truck needs the richest mixture and spark. So the first thing I would check is ohm the injectors, check wires and plugs, check cap and rotor, check for vacuum leaks, check your mas, check for carbon on the intake valves, check your fast idle cam position and or aac valve, check throttle position, see if the egr is sticking, check your timing, check your air and fuel filters etc I almost forgot check fuel pressure and the regulator Edited May 13, 2014 by byob Link to comment Share on other sites More sharing options...
Nissanland Posted May 15, 2014 Share Posted May 15, 2014 The most likely cause you have is the exhausts manifolds are cold and don't have a good seat until it warms up and the metal expands getting a good seat. You probably hear a tick that like xylicon says for 10/20 seconds when you first start up. Very common in the pathfinder engine Link to comment Share on other sites More sharing options...
txpath4x4 Posted May 18, 2014 Author Share Posted May 18, 2014 The slight miss was seemingly caused by what I call a shield wire not connected to the maf ground wire I can take a pic and maybe get it posted ? Link to comment Share on other sites More sharing options...
joejk1 Posted May 18, 2014 Share Posted May 18, 2014 that would be great if you could post a pic please Link to comment Share on other sites More sharing options...
Nissanland Posted May 18, 2014 Share Posted May 18, 2014 Heck if you have found and can fix great...hope I was wrong above, was just an opinion based on my own rig.. hope you have a smooth ride. Link to comment Share on other sites More sharing options...
txpath4x4 Posted May 23, 2014 Author Share Posted May 23, 2014 That bare wire is a shield ground. Stopped the morning miss Link to comment Share on other sites More sharing options...
Alkorahil Posted May 23, 2014 Share Posted May 23, 2014 How did that get that way? Link to comment Share on other sites More sharing options...
txpath4x4 Posted May 25, 2014 Author Share Posted May 25, 2014 Idk I guess the po had ground issues cause he ran that blue wire from the maf to a ground. The shield wire was just chilling bit hooked up Link to comment Share on other sites More sharing options...
