front nhub assembly 1998 pathy.. need to replace.
captandy
The drive flange that houses the bearings? I'm not sure exactly what you are refering to as they shouldn't be a failure point. Can you look at this diagram and see if that is what you mean?
https://partsouq.com/es/catalog/nissan/part?catalog=EL&model=R50&group=400
That has to be the BEST online diagram site i have ever been to, THANK YOU FOR SHARING!!!
*goes to quiet part of the house and geeks out over drawings for several hours....
-Kyle
40202-0W091 sounds right for the hub assembly. The last time I purchased a new hub, it included new inner/outer bearings and an inner grease seal. It won't include hub flange studs or lug studs, though.
There's no difference between left and right.
does this look right? no difference between left or right?
Nissan Part: HUB ASSY-ROAD WHEEL,FRONT Part NO.: 40202-0W091
The Front hubs on the R50 Pathfinder 4WD are the same right or left.
However......
Part number 40202-0W091 is for a 1998 model Pathfinder,
A 2004 Pathfinder uses 40202-0W094
