captandy Posted March 24, 2014 Share Posted March 24, 2014 does this look right? no difference between left or right? Nissan Part: HUB ASSY-ROAD WHEEL,FRONT Part NO.: 40202-0W091 Link to comment Share on other sites More sharing options...
PrestonBurns Posted March 24, 2014 Share Posted March 24, 2014 There shouldn't be a difference. I'd just replace it with manuals either way. Link to comment Share on other sites More sharing options...
Precise1 Posted March 24, 2014 Share Posted March 24, 2014 The drive flange that houses the bearings? I'm not sure exactly what you are refering to as they shouldn't be a failure point. Can you look at this diagram and see if that is what you mean? https://partsouq.com/es/catalog/nissan/part?catalog=EL&model=R50&group=400 B Link to comment Share on other sites More sharing options...
ferrariowner123 Posted March 26, 2014 Share Posted March 26, 2014 The drive flange that houses the bearings? I'm not sure exactly what you are refering to as they shouldn't be a failure point. Can you look at this diagram and see if that is what you mean? https://partsouq.com/es/catalog/nissan/part?catalog=EL&model=R50&group=400 B That has to be the BEST online diagram site i have ever been to, THANK YOU FOR SHARING!!! *goes to quiet part of the house and geeks out over drawings for several hours.... -Kyle Link to comment Share on other sites More sharing options...
XPLORx4 Posted March 26, 2014 Share Posted March 26, 2014 40202-0W091 sounds right for the hub assembly. The last time I purchased a new hub, it included new inner/outer bearings and an inner grease seal. It won't include hub flange studs or lug studs, though. There's no difference between left and right. Link to comment Share on other sites More sharing options...
Precise1 Posted March 28, 2014 Share Posted March 28, 2014 Why did you need a new hub? B Link to comment Share on other sites More sharing options...
Alkorahil Posted March 29, 2014 Share Posted March 29, 2014 does this look right? no difference between left or right? Nissan Part: HUB ASSY-ROAD WHEEL,FRONT Part NO.: 40202-0W091 The Front hubs on the R50 Pathfinder 4WD are the same right or left. However...... Part number 40202-0W091 is for a 1998 model Pathfinder, A 2004 Pathfinder uses 40202-0W094 Link to comment Share on other sites More sharing options...
