UPDATE - Unfortunately, the data that was lost is unrecoverable by the host.  If you joined between May 26th and Jan 13th please feel free to sign up again.  In addition, all posts and messages during that time have also been lost.  At this point there is nothing that can be done, other than to move forward from here.
Thank you for your patience and understanding.
-NPORA Mod Team
*Updated: 02/06/2022 5:26PM PST
My Nissan addiction is growing! Nissan for life! :)
Kyle94
i would just swap in a ka24de/altima trans setup. its a much better engine and would make that sentra a seriously fun car. your mileage will be nearly as good if not the same and you will have 155 hp 160 lb ft torque with a seriously bulletproof timing chain driven engine. you can usually get good shape ka24des for 150-200$ and ecus and harness are cheap as well, worth looking into anyways if you want to have a little upgrade :P i can say nothing but good things, my ka24de i have driven hard and maintained well its whole life and its at 270k KM and still pushing 180 psi on all cylinders. just had it smogged and it read literally 0 0 0 and 1 in the columns. it was better than just about any new car the guy running the thing said and its on a factory 21 year old cat with a full tune up otherwise. i have put the last 100 000 km on the car and the only thing i had to replace was the factory water pump. which on this engine takes about 20 minutes total. LOL
If I had the money id rather go sr... They end up I. Junkyards a lot in sentra. As Dennis said 5spd limited slip transmission. And over 130 hp. And only swapping parts.
I had the bottom end of the engine rebuilt on my Miata shortly after I bought it. Someone chime in if I'm wrong but, if I remember correctly, the rods and crankshaft are balanced.
Yes. But that requires machine work. Kyle wont do that.
Pull the intake. Take pics of the gasket.
It sounds like a bad ass intake leak.
FYI, you will loose cylinders (not compression) from this. Take the 5 minutes too do so. Might end up saving you some money.
Not that I really care. Just giving advice.
Edited by nismothunder
True, just sucks, 12mpg is killing me lol. No matter how I drive pathy it's the sane I swear... :blink: sentra would/should get 20-30
Wheels and tires are too heavy if you're only getting 12 mpg. I get 15-17 on wheelin trips.
SR20 also came in the 200SX
Only in the SE-R though. And please don't call it a 200SX. It's offensive to the REAL 200SX. The two door B14 sentra in SE-R trim is rare, relatively speaking, so good luck finding one.
newer sentra's say 200sx on the ass iirc... but yeah, something is WRONG with my truck. and i can't figure out/afford to pay. so it becomes wheeler and sentra becomes dd
I suppose it's possible. But it's either head gasket set for 120$ or engine, trans, and 800mile clutch for $200. :) I'll investigate it later since I actually get to keep the block.
