HELP! i need a torsion bar rear anchor arm
stabworthy
Do you want me to put this in the Classifieds/Parts Wanted section?
I know you can get all the parts here!
Make sure to mention you are a NPORA member!
WWW.FACTORYNISSANPARTS.COM
phone 1-866-742-0297
Rob Lacy
Parts Department
1-866-742-0297
1-214-491-6565
At the local yards, often a tranny is removed and the vehicle is always suspended, so getting to an anchoring arm or two shouldn't be terribly hard. :shrug:
To the rescue!
54210-31G10
ARM ANCHOR, RH
$35.40
54211-31G10
ARM ANCHOR, LH
$35.40
If they are seized up you will also probably need a bolt and pivot (one each per side) for the anchor as well:
54215-31G0A
PIVOT, ANCHOR
$5.83
54216-31G0A
BOLT, ANCHOR
$7.79
its off, just destroyed , the spline was rusted and twisted inside. the bar looks good, surgeon with a cut out wheel and air chisel :dance:
To the rescue!
54210-31G10
ARM ANCHOR, RH
$35.40
54211-31G10
ARM ANCHOR, LH
$35.40
54215-31G0A
PIVOT, ANCHOR
$5.83
54216-31G0A
BOLT, ANCHOR
$7.79
pm'ed sir
