stabworthy Posted November 20, 2013 Share Posted November 20, 2013 torsion bar rear anchor arm is seized to my torsion bar, does anyone have a spare willing to past with or know where i can get one besides a JY (last thing i want to do fight that bear) Link to comment Share on other sites More sharing options...
Precise1 Posted November 20, 2013 Share Posted November 20, 2013 Do you want me to put this in the Classifieds/Parts Wanted section? I know you can get all the parts here! Make sure to mention you are a NPORA member!WWW.FACTORYNISSANPARTS.COMphone 1-866-742-0297Rob LacyParts Department1-866-742-02971-214-491-6565 At the local yards, often a tranny is removed and the vehicle is always suspended, so getting to an anchoring arm or two shouldn't be terribly hard. B Link to comment Share on other sites More sharing options...
adamzan Posted November 20, 2013 Share Posted November 20, 2013 You might be able to free it by using a small torch, some pb blaster and a hammer. Other than that either a dealer or the JY is your best bet. Link to comment Share on other sites More sharing options...
Alkorahil Posted November 20, 2013 Share Posted November 20, 2013 To the rescue! 54210-31G10 ARM ANCHOR, RH $35.40 54211-31G10 ARM ANCHOR, LH $35.40 If they are seized up you will also probably need a bolt and pivot (one each per side) for the anchor as well: 54215-31G0A PIVOT, ANCHOR $5.83 54216-31G0A BOLT, ANCHOR $7.79 Link to comment Share on other sites More sharing options...
stabworthy Posted November 21, 2013 Author Share Posted November 21, 2013 its off, just destroyed , the spline was rusted and twisted inside. the bar looks good, surgeon with a cut out wheel and air chisel To the rescue! 54210-31G10 ARM ANCHOR, RH $35.40 54211-31G10 ARM ANCHOR, LH $35.40 If they are seized up you will also probably need a bolt and pivot (one each per side) for the anchor as well: 54215-31G0A PIVOT, ANCHOR $5.83 54216-31G0A BOLT, ANCHOR $7.79 pm'ed sir Link to comment Share on other sites More sharing options...
