fearkobe Posted November 10, 2013 Share Posted November 10, 2013 (edited) 95 path 4x4 is it bad to run 1 diffrent tire out of the other 3 tires that are the same? Itt's all the same size just diffrent treads and loading range. The other 3 a loading range c and the 1 is a loading range b. Also that one tire i bought diffrent according to the junk yard I was told that it was a spare tire cause someone had bought it before and brought it back because they were told its a spare tire and it says nothing anywhere on the tire its a spare tire only. Heres the pic of the 1 diffrent tire. http://postimg.org/image/hogl88t99/ Edited November 10, 2013 by fearkobe Link to comment Share on other sites More sharing options...
fearkobe Posted November 10, 2013 Author Share Posted November 10, 2013 tried uploading images but having a hard time. all the tire says its a good year wrangler. also a friend told me this would be bad for my transfer case but i rarely use the 4x4. he said the transfer case is always moving. i told him it shouldnt matter unless im wrong? Link to comment Share on other sites More sharing options...
5523Pathfinder Posted November 10, 2013 Share Posted November 10, 2013 What you need to be worried about is a size difference, especially side to side. Two different tires turn at two different speeds and you will break things in the differential. A tire that is just a different tread and load, can case some noise and pulling issues. For a short time, it's no big deal, but don't run it that way forever, unless your a dedicated trail rig. Make sense? Link to comment Share on other sites More sharing options...
fearkobe Posted November 10, 2013 Author Share Posted November 10, 2013 hardly take it off road like too one of these days. i'll make sure to have the same tires all around. does anyone have a problem with balancing the tires with lego rims? seems like i have to balace them often. Link to comment Share on other sites More sharing options...
bushnut Posted November 10, 2013 Share Posted November 10, 2013 buying cheap / potentially damaged tires is the problem with balancing not the rims. you get what you pay for. Link to comment Share on other sites More sharing options...
adamzan Posted November 10, 2013 Share Posted November 10, 2013 You can run one different tire on the front for as long as you want, but only if you do not use the 4wd, as the diff won't turn with the hubs unlocked. I have 2 different pairs on mine right now, but that is front to back, and is done all the time. I would try and at least get a pair that matches. Especially the same load range. Link to comment Share on other sites More sharing options...
mfoley412 Posted November 10, 2013 Share Posted November 10, 2013 Yeah new tires make a world of difference I just ended up buying a set of BF Goodrich A/T tires after going through what it sounds like you are for a minute. $600 though for the set of 4 mounted and balanced. its a pretty penny but once you get some new tires you will be much more comfortable. Link to comment Share on other sites More sharing options...
nunya Posted November 10, 2013 Share Posted November 10, 2013 I'd like to see at least matched on an axle but have been in a bind and done it waiting for something to come in with tires I needed. That wrangler you have in the pic link though you probably won't have to worry about that one long (I never see them get any miles) Link to comment Share on other sites More sharing options...
fearkobe Posted November 10, 2013 Author Share Posted November 10, 2013 buying cheap / potentially damaged tires is the problem with balancing not the rims. you get what you pay for. i dont mind buying used tires i know the risk of buying used tires. its either the weights fall off or something else like the tire. Link to comment Share on other sites More sharing options...
fearkobe Posted November 10, 2013 Author Share Posted November 10, 2013 I'd like to see at least matched on an axle but have been in a bind and done it waiting for something to come in with tires I needed. That wrangler you have in the pic link though you probably won't have to worry about that one long (I never see them get any miles) ya looked brand new but i see its wearing. debating if i want to have it thrown in the back. when my brother inlaw bought off of me awhile back and ebven the tires were wearfing out in the back too must be that lsd. Link to comment Share on other sites More sharing options...
fearkobe Posted November 10, 2013 Author Share Posted November 10, 2013 Yeah new tires make a world of difference I just ended up buying a set of BF Goodrich A/T tires after going through what it sounds like you are for a minute. $600 though for the set of 4 mounted and balanced. its a pretty penny but once you get some new tires you will be much more comfortable. ya i was gonna buy some hercules all trac A/T for 380 mounted and balance but money was tight. Link to comment Share on other sites More sharing options...
nismothunder Posted November 10, 2013 Share Posted November 10, 2013 (edited) I ran 1/2 inch different height tire on mine when it was stock. I wheeled the piss out of it too boot. Never broke anything. If you have a lsd rear and are worried about maybe burning the clutches up you can run it on the front. I would not worry about the transfer case or anything being hurt. Edited November 10, 2013 by nismothunder 1 Link to comment Share on other sites More sharing options...
mfoley412 Posted November 11, 2013 Share Posted November 11, 2013 ya i was gonna buy some hercules all trac A/T for 380 mounted and balance but money was tight. Yeah not really a big deal. I ran different sizes too, just 2 of the same on the front and 2 of the same on the back. Not going to hurt anything really (although people have told me not to run the 4wd with the different tire sizes..). 1 Link to comment Share on other sites More sharing options...
