William Posted January 31, 2013 Share Posted January 31, 2013 Hi.I did some research and came across the following parts from an R50: - 96400-1W610 (driver side) - 96401-1W610 (passenger side) The objective is to retrofit these in my 1992 since mine did not come with mirrors or lamps on either side.Q: Will I be able to retrofit them in my 1992?This is how my 1992 Visors look like: William Link to comment Share on other sites More sharing options...
Reshma Posted January 31, 2013 Share Posted January 31, 2013 My X has those ugly ass things. No mirrors. :CI'm going to watch this thread. Link to comment Share on other sites More sharing options...
Trogdor636 Posted January 31, 2013 Share Posted January 31, 2013 Just by eyeball measurement they don't seem like they will just bolt up. I'd get a measurement to check. If you don't mind getting creative I'm sure you could figure out how to mount them. Link to comment Share on other sites More sharing options...
Slartibartfast Posted January 31, 2013 Share Posted January 31, 2013 It would probably be easier to find a set of lighted WD mirrors at a junkyard and install those. The mounts should be the same, and the lights/mirrors look to be a little bigger than in the R50 shades. If you need a pic of the WD ones for reference lemme know. Link to comment Share on other sites More sharing options...
MY1PATH Posted February 1, 2013 Share Posted February 1, 2013 Well, the added beifit being a dual sunshade as well. I forgot all about those, I wonder if that R50 is still in the JY. Link to comment Share on other sites More sharing options...
Tungsten Posted February 1, 2013 Share Posted February 1, 2013 (edited) There are some units that have the big mirrors and lights in them. I picked up a set along with the map light at the junkyard and wired all that stuff in. Everything came out of a newer WD21. Edited February 1, 2013 by Tungsten Link to comment Share on other sites More sharing options...
Trogdor636 Posted February 1, 2013 Share Posted February 1, 2013 And most likely a SE. Link to comment Share on other sites More sharing options...
Inyourface1650 Posted February 2, 2013 Share Posted February 2, 2013 Mine has them, but - for future reference, was the wiring all there or did you have to run new wires? Link to comment Share on other sites More sharing options...
Tungsten Posted February 3, 2013 Share Posted February 3, 2013 I had to make a wiring harness that took power from the dome light circuit. On the real deal, the power for the visors comes from the marker lamp circuit. You have to turn the parking lights on to use the light on the visors. I just wanted them to light up when open which made more sense to me. Link to comment Share on other sites More sharing options...
vagabond Posted February 3, 2013 Share Posted February 3, 2013 I installed a pair from a 97 QX4, if I remember I had to enlarge the hole where the shaft goes up. As to the wiring I tapped into the the dome lite which also feeds the map lights. The brackets that holds the ends had to be moved slightly, you'll have to drill a couple of holes all in all it was a pretty simple install and the wife really likes the double visor. I picked the visors up at the same time I got the console and shifter, and the QX4 emblem now sits in the lower left corner of my rear hatch window Link to comment Share on other sites More sharing options...
