1993 Pathfinder partial restor
rollingrock
Hey folks, (Lots of photos broken into several posts)
I am new here and already learned a ton, my thanks to all of you who have held my hand. I am still learning
Since buying this 93 last week, I have done the following:
New Rancho 5000 shocks
New sway bar bushings, front and back and new end links
passenger and driver side half shafts replaced
gas struts on rear lift gate and glass replaced
1 new tire
alignment
torsion bars tightened
And being a paint restoration guy by hobby, I went after the exterior this past weekend. I only put about 20 hours into it.
Here are some photos taken from a thread I started at The Detailers Cafe.
This is what I am working with.
I am taking a little break
Flex and 7424 with black Megs Finish pads...using PB PP just to clean the surface
Blue Megs clay
Baseline
Prewash with my little man
Here she is getting ready
Shot of hood, you can clearly see the road grime and tree sap and junk on the left side. The right side is already cleaned and prepped.
1x1 foot of hood
Hopefully you see the haze, swirls and junk in the paint
yup, its white folks
Edited by rollingrock
Definitely looks better! :aok:
I'm not sure I have that much patience though...
Thanks man, I only put 20 hours in the paint and detail. ;) I could have put another 20 in it easily.
BikerJared,
Auto Detailing Clay is designed to prep the surface for polish, correction or wax. It removes surface and embedded contaminiantes so that you are not grinding them further into the paint.
It is used with a slick solution (QD, called Quick Deailer or "lube") you rub it on the surface with the proper amount of lube so it doesn't grab . In this case, I had to chemically clean the surface prior to claying.
Hope this helps.
