bushnut Posted November 22, 2012 Share Posted November 22, 2012 so i've been searching this site and others mostly looking at photos of peoples rigs,(lots of inspiration out there) then I look out the window at my pathy and think it almost looks lifted already. I'm probably the 4th owner of "Rusty" she is 12 years old. and someone may have lifted her in the past. so I guess what I need to know is, what is the stock ground clearance? I haven't been able to find that info anywhere. I measured at the centerpoint of the front diff and got about 8" would a 2" AC lift then give me 10"? sorry for all the dumb questions. 2000 R50 se Link to comment Share on other sites More sharing options...
erathge Posted November 22, 2012 Share Posted November 22, 2012 Take some pictures! We should be able to tell. 1 Link to comment Share on other sites More sharing options...
rocky2 Posted November 30, 2012 Share Posted November 30, 2012 Measure the lifting blocks under the sub-frame. Link to comment Share on other sites More sharing options...
sroeser01 Posted December 1, 2012 Share Posted December 1, 2012 i was wondering this myself, i have 35 inches from ground to the center of the rear wheel well 33 inches to the center of the front wheel well. also i have 16 inches from the ground to the rear hitch and 15 inches from the front tow hooks to ground, dont know if this helps or not but im not sure what stock is? anyone ? Link to comment Share on other sites More sharing options...
devonianwalk Posted December 1, 2012 Share Posted December 1, 2012 Actual lift is measured from the center of the wheel hub to the bottom of the fender. Link to comment Share on other sites More sharing options...
sroeser01 Posted December 2, 2012 Share Posted December 2, 2012 so what are some peoples numbers? it would be interesting so see if its at all consistent with the different lifts out there Link to comment Share on other sites More sharing options...
silverton Posted December 2, 2012 Share Posted December 2, 2012 The only thing that is going to gain you more clearance from the differential to the ground is taller tires. suspension and body lift (or a subframe drop in the r50's case) allows you to run taller tires to get more actual ground clearance. 1 Link to comment Share on other sites More sharing options...
